3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Do-nothing Machine
Step 5Glue Top Layer
Glue Top Layer
Gather the four top layer squares.
1) Find the corner on the base that we marked in step three. Again place the best corner towards the center of the base and glue and clamp into place. By placing the slider assembly correctly you will be able to use those as spacers to position this layer correctly. Make sure the sliders and corner have a close fit. Clamp in place. Check the make sure no glue seeps into the channel. Don't let any dry. You will have a difficult time removing it.
2) Now turn the lever so that the sliders move to align the next layer. Glue clamp and wipe extra glue again. Repeat this for all the corners rotating the lever every time. You may have to remove some clamps to spin the lever into the correct place. I waited for the first two corners to dry before moving on.
3) Let everything dry for the recommended about of time, about 24 hours. You do not want to put strain on the joints while they are still drying.
4) Now that everything is dry try to twist the lever, It should move in an elliptical path. There will be resistance but with use this will be reduced. Mine will only spin clockwise as there is some hang up due to the lever bending when I drilled the holes. Try both ways before determining that you need to start over.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:LeumasYrrep
Currently a Mechanical Engineering Student at RIT
