Dog Food Dispenser
385
8
Posted
Introduction: Dog Food Dispenser
Items list
  • 2 x sheets of 3mm acrylic at least 400x600mm
  • 3d printer (to print helix screw)
  • 1 x 10mm diameter acrylic tubing
  • Laser printer (to cut stands and lid)
  • Arduino (I'm using uno)
  • Hacked servo motor
  • Acrylic glue
  • 1 bag Iams mini chunks
  • 1 x dog bowl
  • 1 x sheet (540x540mm) HIPS
  • Vacuum form machine
Step 1: Step 1:Cutting
  • Cut out the shapes on a laser cutter using 1 sheets (400x600mm) 3mm thick acrylic
  • Print the helix screw on the 3D printer
Step 2: Step 2: Creating the Food Hopper
  • Create a dome shape with a diameter of 300mm and depth of 100mm Using a vacuum former and an appropriate mould using 1 sheet (540x540mm) HIPS
Step 3: Step 3 : Acrylic Tubing
  • Source 600mm length of acrylic tubing with 65mm inside diameter and 70mm outside diameter. Cut the tube at an angle of 45 degrees 300mm from one and fix the cut angle together at 90 degrees using acrylic cement.
  • Source 20mm of 20mm diameter acrylic tubing.
Step 4: Step 4:Coding and Wiring Layout
Connect the servo motor to the arduino
  • white wire to pin 10
  • Red wire to 5v
  • Black wire to ground
Code
Download the two files to arduino first before adding the code, this will allow you to use the Alarm.
#include <TimeAlarms.h>
#include TimeLib.h>
#include <Sero.h>
Servo myservo;
void setup()
Serial.begin(9600);
setTime (8,29,50,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
// create the alarms
Alarm.alarmRepeat(8,30,0, MorningAlarm); // 8:30am every day
myservo.attach(10); }
void loop()
Alarm.delay(3000);
void MorningAlarm()
for (int i=1; i<=3; i=i+ 1)
delay(100);
myservo.write(360);
delay(10000);
Step 5: Step 5: Assembly
  • Drill 1 20mm hole in the shorter side of the acrylic tube about 150mm from the end. And another hole the same size in the centre of the dome.
  • Slot the 20mm acrylic tube between these holes and fix in place.
  • Fit the 3D printer helix to the motor and slot inside the acrylic tubing along with the Arduino and wiring.
  • Slot the stands onto the acrylic tubing and fix in place.
  • Fit the vacuum formed dome onto the 20mm hole and fill with dog food.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
