loading
loading
Picture of Dog Toys for Heavy Chewers
These easy to make colorful rope toys are great for any size dog. Just scale up or down the diameter of the rope to fit your dog, 1/4" for small dogs or 3/8" for large dogs. Directions given are for a basic toss/tug toy pictured below. Pictured are several variations based on the basic knot that can be created with a little practice and creativity.
Step 1: Finding center of two lengths of rope
Picture of Finding center of two lengths of rope
Start with two equal lengths of rope, I recommend no shorter than 5' each length. Find the middle of each length by folding the rope in half and lining up the cut ends.
Step 2: Finding Middle of each Rope
Picture of Finding Middle of each Rope
After locating the middle of each rope, cross each rope at right angle to other rope.
Step 3: Secure with small Zip Tie
Picture of Secure with small Zip Tie
 Then use a small zip tie to secure to the two lengths together at the centers.
Step 4: Begin the knot
Picture of Begin the knot
Lay crossed ropes over fisted hand with thumb extended.
Step 5: Loop around thumb
Picture of Loop around thumb
Loop first rope around thumb and over second rope, using thumb to hold first rope in place (see image)
Step 6: Loop Second Rope
Picture of Loop Second Rope
Loop second rope over first rope and go over rope three, using thumb to hold in place.
Step 7: Loop third rope
Picture of Loop third rope
Loop third rope over second rope and go over forth rope, use thumb to hold third rope in place.
Step 8: Loop fourth rope
Picture of Loop fourth rope
Loop fourth rope over third rope and then insert fourth rope into loop created by first rope.
Step 9: Tighten up Loops
Picture of Tighten up Loops
Tighten each rope by pulling the tail of each rope.
Step 10: Continue to tighten loops
Picture of Continue to tighten loops
Pull all ropes tight until a small four section knot is created.
Step 11: Trim off zip tie
Picture of Trim off zip tie
Trim off zip tie tail, and place knot with zip tie side facing up.
Step 12: Repeat steps 5-9
Picture of Repeat steps 5-9
Repeat steps 5-9. Loop first rope around thumb and over second rope.
Step 13: Repeat steps 5-9
Repeat steps 5-9. Loop second rope over first rope and over third rope holding in place with thumb.
Step 14: Repeat steps 5-9
Repeat steps 5-9. Loop third rope over second rope and over fourth rope holding in place with thumb.
Step 15: Repeat steps 5-9
Repeat steps 5-9. Loop fourth rope over third rope and feed tail of fourth rope into loop created by first rope.
Step 16: Tighten up all Ropes
Picture of Tighten up all Ropes
Continue to tighten up all ropes pulling together to form a four section tight knot.
Step 17: Tightened Knot
Picture of Tightened Knot
Tightened knot shown here from above and side view.
SparkySolar5 months ago
Thank you for this nice Instructable. I like it
Rima
jasher27 months ago
Please add a note about playing only with supervision. Working as a surgery tech for a vet clinic, I see braided toys need removing all too much.
shaydawn made it!7 months ago
Just made this for my dog Jax, he DESTROYS most toys so we will see how long it lasts! Nice instructable though, very easy to understand and not a difficult idea! Thank you!
pattybe5212 months ago
I have made several of these toys for myself & friends. It holds up to lots of hard play! I haven't been able to figure out the weaving the ends back in, so I have used a bit more rope & tie the ends to make it more of a retrieve toy. It works wonderfully as a tug toy for 2 dogs that way!
ccroft11 year ago
How do you make the loop one? Have a yellow lab that destroys everything and its my turn to win.
farley1232 years ago
Is hemp rope the correct rope to use? Don't the strands get wound around the dogs intestines ?
bwest122 years ago
I've attached a pic of the toy I made using your instructable! Below it is the 10" tent stake I was using as a marlinespike. Thanks again!
bwest122 years ago
Just finished making one for my Belgian Malinois/Pitbull mix. He's a rescue a bit over a year old and he's got a heart of gold. The guy loves to chew and play! I took this outside and he immediately started playing tug of war with it and all around being a goof. I tucked the ends and melted them, but didn't snip them, I left about 6" on each end. He likes to grab the toy by one of the tassles and sling it around. Thanks for the instructable!!!! :D
pblanchard22 years ago
Any idea how to make this into a ball? Maybe into a cover to go over a ball?
pblanchard2:
Try the "Monkey Fist"! http://www.igkt.net/beginners/monkeys-fist.php I've made a few of these in the Navy to use as heaving balls. Now be careful though, because these make hard balls (my dog LOVES chewing on his though) and if thrown at someone (or a pet!) would feel like being hit with a baseball. You can modify it with a few extra turns or some larger rope. I usually use 3/8" rope to make a fist slightly smaller than my own. A marlinespike (http://en.wikipedia.org/wiki/Marlinspike) (I use a long 10" steel tent nail) will assist you with pushing/pulling the last few turns of the rope through the fist to make it good and tight. My favorite tug toy for my dog (Belgian Malinois/Pitbull) is a piece of rope I've fashioned with a monkey fist on each end with a braid between them. He loves it!!!
J3443RY (author)  pblanchard22 years ago
Great suggestion on covering a ball I have not tried it but you got my mind in motion! thanks
jemismom2 years ago
Our dog (black lab) is a heavy chewer. I was so excited to try this and will say it was quite easy to do (great instructions! Thanks!). However, we made the Y shape toy and she had it torn apart in less than an hour. It looks like a small stick with a bunch of alien tentacles sticking out of it now. We tried the circle ring next and the circle came apart in about 10 minutes, it doesn't look like it will last more than a day either. I twisted and tied and tucked the ends in so not sure why its so 'fragile', but any suggestions would be appreciated. I love this idea, but we need more than an hour out of it :-)
how did you mahe all of the different shapes. i only knw how to make one of the ones you made in this instructable and that was just the straight one. can you write another intstructable for the other shapes
J3443RY (author)  shadow wave rider3 years ago
Well I have finally released a new Instructable based on my original Dog Toys for Heavy Chewers this time it features a "Y" Shaped Dog Tug & Toss Toy more shapes and more instructables are in the works. So keep checking in to see the progress. Thanks for your interest.
Thanks & Yes I am working on that now, keep checking in
djlewis7254 years ago
Hey Please make an instructable on how to connect ropes to make something like in your example. Great ible
J3443RY (author)  djlewis7253 years ago
irish2ice5 years ago
Awesome, Awesome, Awesome......
PLEASE, PLEASE, PLEASE do an instructable showing how to do this with a Double loop!!  Just like one of your examples, but with double loops!!
J3443RY (author)  irish2ice3 years ago
iamrusky4 years ago
wow. this is ... AWESOME! Christmas for my Seamus pup. this is so similar to gimp lanyards.they were super popular in the nineties, make super key chains.
Great job! My pup will love this!
cwissduhfur5 years ago
isnt that just a lanyard with rope?
pitbull2775 years ago
A hemp or cotton rope would not be harmfull if eaten, but cotton wouldnt be as tough.
Oops, how do I vote for this?
BTW, I voted for this :) No strings attached as I don't have any ibles yet (pun intended).
Rottmaster5 years ago
These toys are great but make sure that after you are finished playing with your dog that you pick up these kinds of toys beacuse if your dog eats the string it can kill him.
It is always a good thing to pick up all toys after playing with your dog.
instruct395 years ago
Really great instructable I give it 4.5*. I will definatly make one of these for my own dog once i get some paracord.
pie R []ed5 years ago
 you should really make this out of paracord and put it in the contest!
Excellent! I will be making a few of these for my grandson's dog who is a German Shepherd still in the puppy chewing stage at 2!
Biggsy5 years ago
Yuo know I have always wondered how they make those! Thanks alot, really welldone instructable!
mg0930mg5 years ago
I think this looks like those barrels we used to make with gimp. This looks promising and nice, though.
