Dog's Toys Barrier
Introduction: Dog's Toys Barrier
Have you ever got into this situation?
Picture this, you have a dog, and when playing all the toys ends under the sofa.
Two things can happen, the dog gets anxious and starts bothering, or gets sad and gives at you "that look".
I thought that i was the only one who happens this, until i found this image on the net (a dramatic version, but same problem), and started this solution.
Step 1: Materials and Tools
I thought on a design that must fulfill three conditions:
-Needed to be cheap
-Easy to install and remove
-No special skill required, so to be made by everyone.
After that, i found this solution, with materials that could be found on Walmart for less than $ 10 USD.
-You will need a few swimming noodles (the kind with a hole in the center)
-Some rope
-A piece of metal or a stone, small and heavy enough to get trough the hole of the swimming noodles.
Step 2: Preparation
First, we measure the space we need to cover.
If it's more, we might complete it with another piece of another swimming noodle.
Step 3: The Making
The first step is to pass the rope through the swimming noodle.
Then, we make a simple knot in one "leg" of the couch.
In my case, i have an "L" shaped couch, so i used a knot to make a "brake". The rope is longer and i dont want the swimming noodle to be moving.
Then, i cuted the rope about a foot longer than necessary, in order to make the other knot.
Repeating this simple step, you can make as many barriers as you need.
Step 4: Repeat As Needed.
With this few basic steps, you can block any surface that gives you trouble.
-Measure and cut.
-Pass the rope through the noodle.
-Make a knot one end, cut the rope with an extra, tie the other end.
Step 5: One More Time.
-Measure and cut.
Your pet will thank you.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    That's a good idea with a great price point.
    Thank you, i appreciate you took some time to give a look at this instructable.
    Thanks, it's hollow to put some pet snacks inside.
