3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Domo Kun Night Lamp
Step 3Details on Domo Kun
Details on Domo Kun
1. Cut out the details we need to the Domo Kun
 - Teeth (use the white paper)
 - Red mouth (I used a red part of a plastic bag)
 - Eyes (use black paper for this one, I got this from a magazine)
2. Tape the white teeth and red part on the back (inside) of the Domo Kun.
Then glue the eyes on.
3. Once the glue is dry you can make a hole in the back piece of the Domo Kun.
I made this hole so my On/Off toggle switch can fit through there.
This step is not necessary if you use or make your own switch.
A toggle switch will just make it easier to switch the light on and off. But any switch or home made switch will do.
4. Next thing you want to do is close the Domo Kun by folding the edges together and hot glue it so it will stay that way.
Don't glue the bottom side. This need to stay open so we can put the electronics in.
I used hot glue (glue gun) for glueing so it will stay nice and tight and won't be noticeable from the outside.
If you don't have a glue gun. You can also tape the inside with duct tape or another strong tape.
You should now have the same as I have in my last photo below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
190
Author:motadacruz(www.motadacruz.nl)
