Step 2Cut it out!
Cut out two pieces of the flat parts of the plastic container in the size/shape you want. Mine was about 3 inches x 2 inches. You could also do circles or other shapes, but you need to round off any corners because corners will get sharp when shrunk. (note: all plastic doesn't melt the same and keep the same proportions, so cut both pieces running the same way. e.g. if you're doing 2 rectangles, cut out one large rectangle and cut it in half to ensure your pieces run the same way. If you're doing circles, be sure to mark the top and put your holes in the same place.)
If there is any impressions on the plastic (like the #6 symbol, or words) you can just color over it and it will go away in the shrinking process. But be aware it may be a pain to color or draw lines over.
On each one, use a hole punch to make a hole in the top center.
Thanks,
R
