Introduction: Door Alarm
Picture of Door Alarm
This is a great and easy project to do for starters and experts
You will need a -screw driver
-NC or NO reed switch
-9 volt battery
-9 volt battery clip
-3 jumper wires
-active buzzer
-breadboard
Step 1: Step 1
Picture of Step 1
Put the active buzzer on the breadboard
Step 2: Step 2
Picture of Step 2
Connect the positive pin of the buzzer to com on the reed switch
Step 3: Step 3
Picture of Step 3
Connect the negative pin in the buzzer to the negative rail on the breadboard.
Step 4: Step 5
Picture of Step 5
Connect the positive rail on the breadboard to N/C or N/O depends if you want the buzzer to buzz when the door opens if so connect to N/C, if you want the buzzer to buzz when the door is closed connect to N/O.
Step 5: Finish
Picture of Finish
Now connect the battery clip to the positive and negative rail on the breadboard then plug in the battery and test. You. Can mount this to a door I used blue tack but you can use whatever. If you liked this please like it and also if you need some active buzzers I have some on this link right below.
Active buzzers- http://www.ebay.com.au/itm/182557930221?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
LarsR5 (author)2017-05-24
nice prototype!
If you want to make a usable version the following might help.
If you connect a reed switch to the connectors of a water alarm sensor you have a similar effect.
Conrad in Germany is just selling reduced water alarms fuer some 2,40 Euro.They include buzzer, housing, battery...
https://www.conrad.de/de/wassermelder-mit-internem...
(I made a similar project with them using a microprocessor because I wanted to have a delayed and "growing" alarm)
Kalebs-how2s (author)LarsR52017-05-24
thanks good work making a similiar project
Swansong (author)2017-05-24
Thanks for sharing :)
About This Instructable
131views
6favorites
Bio: enjoy arduino,inventing,diy's and technology check out my ebay at-https://www.ebay.com.au/usr/kalebshow2s?_trksid=p2047675.l2559 website- https://kalebshow2s.weebly ...
More by Kalebs-how2s:Bottle Rocket Awesome!IPad StandZip Lock Bag Science Experiment
Add instructable to:
