Remove these ads by
Signing UpStep 1Materials and tools
One 10' length of 2 x 4 construction lumber, which you will rip into two 1 x 4's. Pick the straightest, cleanest piece you can find. If you don't have a bench saw, you'll need enough 1 x 4 to go around the table - approximately two 7' lengths and two 3' lengths (three 8' pieces is plenty).
One 8' length of 2 x 4 construction lumber, which you will rip into two 2 x 2's. Pick the straightest, cleanest piece you can find. If you don't have a bench saw, you'll need enough 2 x 2 to make the four legs and two crosspieces - approximately six 3' lengths (two 8' pieces is fine).
A bench (or table) saw is necessary to rip the 2 x 4's. A miter saw is handy to cut the wood to length. I used a brad nailer, wood glue, and a few deck screws to assemble the table. Wood filler, an orbital sander, and paint was used to finish the table, but all that is unnecessary if you're just going to use it as a utility table.
If the intended use for this is a computer table then the door handle hole doesn't need to be filled in, it is actually useful for running cables through it.
Also, saves some work.
great reuse for a door. the closest I ever got to doing this was flopping an old door across 2 sawhorse to make a makeshift table .
(your looks much nicer)
maybe i can use this to convince my wife to let me get a nailgun hehehe
I recommend the nailgun. If you don't need the compressor (though it's good for inflating and cleaning things, too), the electric ones work well too.
They're charming boys, really... :)
