Dot Matrix Business Card
Step 2What you need
What you need
  • One CR2032 battery (I got them for about 16 cents on ebay when I bought 100)
  • One CR2032 battery holder (I used part 18-3780 from www.rapidonline.com. This costs around 14 cents in quantities of 100 - these are a common type of holder that you should be able to find at places like www.mouser.com if you are on the other side of the Atlantic to me!)
  • One PIC16F57 (Order code 1556188 from www.farnell.com - These cost 66 cents each in 100+ quantities - again, you can find them at www.mouser.com)
  • Four surface mount switches (Part 78-1130 from www.rapidonline.com at 20 cents each)
  • Some miscellaneous resistors and capacitors in an "0805" surface-mount package - you will need 5x100 ohm resistors, 2x10k resistors, 1x47k resistor, 1x47p capacitor, and 1x100n capacitor - any of the suppliers mentioned above do these, and they cost almost nothing!
  • 75x "0603" LEDS - as bright as possible, and as cheap as possible! I used item 72-8742 at 6 cents each from Rapid, but again, you should be able to get them at other suppliers. In quantity, you can get these down to about 3 cents each.
  • Some double-sided foam adhesive tape that is slightly thicker than the battery you are using - mine was 4.5mm thick)
  • A printed circuit board (PCB) for the project - instructions for producing your own are beyond the scope of this article, but you may have some success with the iron-on or photographic technique (my preferred technique). You can find instructions for making your own printed circuit boards elsewhere on instructables and other sites. The PCB layout is reproduced below in a PDF file if you want to try yourself.
You will also need a soldering iron (plus solder), a cutting knife, some spray adhesive, and a way of printing the front of your card - you can use a colour laser or inkjet. I printed on OHP transparency film. You will also need a way of programming the PIC microcontroller. I use the PICKit2 which is part number 579-PG164120 from www.mouser.com, and available at around $35. A strip of 5x0.1 inch PCB pins (such as 22-0510 from Rapid) can be pushed into the programmer to act as an interface with the board.
MatrixPCB.pdf(595x842) 17 KB
MatrixPCBMirrored.pdf(595x842) 17 KB
6 comments
Aug 14, 2011. 7:28 PMMatthewEnderle says:
got an idea tom to revise the board. Where the Battery is placed cut out a hole and place the battery in the hole, and use tin flaps soldered to the board. That will make it thinner.
Apr 4, 2009. 2:37 PMglocketz says:
Hey, Sunstone circuits (custom pcb manufacturer) requires the matrix to be in either a .RAR, .123, . BRD, or .BIN formats. Can you please upload a copy of the matrix in one of those formats so I can have a circuit printed? Thanks.
Apr 14, 2010. 1:09 AMl4a says:
Hello, I have a bit of a problem. And  I'm asking for a help. I have succesfully soldered everything and programmed it. But it doesn't work as it should. When I insert the battery all the LED's are turned on. Even if I press one of the four switches nothing happens (all the LED's are still on). Could you help me with the problem, please? Thanks
Apr 19, 2010. 6:59 AMl4a says:
Hi again. I'm new in this and I'm having some troubles understanding your solution. Could you please tell me where can I select this fuse/option bit?
Thank you for your time! I really appreciate it.
May 4, 2010. 9:24 AMl4a says:
Well I haven't been able to fix it so I decided ti make another one. And even this one doesn't work. I have checked all the connections and everything seems OK. So is it possible that I have overheated the PIC while soldering?
p.s. Is it possible that you could send me one of your prototypes? I would pay you of course.
Thanks
May 5, 2010. 11:02 AMl4a says:
I think I might have solved the problem. I don't know how I did that but I turned the LEDs up side down! This week I'll try to do another one and I'll tell you the result!
Aug 30, 2008. 6:46 AMF1X0R says:
www.Rapidonline.com FTW!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
101
Author:tomward
