Step 6Finishing Off
iImage Information
To encapsulate the prototype, I applied some double sided foam tape to the board, turned it upside down, and then cut the excess off. I then reverse-printed the graphic overlay on an OHP transparency sheet. By turning the sheet over, and attaching a white printer label, you can get the clear icons on the transparency to show up white. I also attached a sheet of thick polypropylene (made as a cover for binding documents) to the overlay using some adhesive spray before attaching to the front of the card and trimming off the excess. If you wanted to use the same graphic as mine, it is also available on this page as a PDF.
