Step 8The Future
Next, I would like to work on a high-resolution version using a colour OLED display - think photographs and animations. The sky is the limit - almost any electronics could be put into business cards - wireless links, audio soundtracks - if anyone is interested in using these ideas or other related ones commercially, then let me know - you can reach me at info@lightboxtechnology.com.
At the bottom of this page I have included the Eagle PCB file for this project. Be warned that it is a slightly different version than the one shown in this instructable, so won't be much use unless you are familiar with Eagle and are happy to make some modifications for your own use. The main changes are that it is double-sided (no need for the tape/wire combination in step 4), the switch type has a slightly different footprint, and I use a different style of battery mount. (For those that want to try it, I drilled a 20mm hole in the centre of the PCB, and then used two diagonal pieces of spring wire on either side of the board to hold the battery in, to make a much thinner finished card).
Led Card.brd35 KB| « Previous Step | Download PDFView All Steps | Next Step » |
7
comments
Add Comment
tomward (author)
says:
tomward (author)
says:
tomward (author)
says:
Add Comment
