iImage Information
This is a BB machine gun I made. It has two seperate inline vortex blocks inside and fires 6MM airsoft bbs. The gun and tripod are made completely of PVC pipe or sheet and hot glue with the actual innards made from wood and metal. The body is 4" PVC and the barrel shrouds are 3/4". The tripod is also 3/4" PVC pipe. I ran out of spray paint so I can't paint all of it right now. I am also planning to build a .177 cal minigun in the near future.
Also, thank you!
Also if you use wood I'd suggest sleeving the hole with PVC because I don't know how much abuse the wood will take by itself.
Oh and if you want to make it a bit more portable you could; get a car battery run smallish compressor, and a car battery, connect them up to your gun and store them beside your gun in a box designed to look like an ammo box, it would mean it would be sorta portable, iv seen some guys do it before its pretty impressive if it works.
That sounds like a great idea, but I built it mostly for show and doing all that really isn't for me.
