Need a highly portable USB power source that can be replenished with readily available, common batteries?
The MintyBoost from adafruit Industries is an awesome little kit that nets you a USB charger that runs on 2 AA batteries. This is a great thing because AA batteries are available anywhere and together with the MintyBoost can be used to power most USB devices when you find yourself in a situation with no other source of power. As a volunteer providing emergency communications for organizations that are deployed to disaster stricken areas I have been in this situation before. Keeping critical communications links operational in the field is a major mission success factor. Having a highly portable source of USB power to keep cell phones working is a valuable tool for the first responder. There are, of course, many other uses for portable USB power. One of my favorites is extending the play time of graphic intense iPhone games while traveling.
This charger does more then just provide the 5 volts required to charge USB powered devices. The circuit incorporates a DC to DC boost converter that is able to draw power from batteries that may otherwise be considered "dead". Also known as a "Joule thief" this means you get more output from your battery power investment.
After building my first MintyBoost kit I immediately looked for a way to increase the charging capacity of the device. I noticed that a commonly available 4 AA cell battery holder will fit perfectly into a regular (pack of cards) sized Altoids tin with the MintyBoost. And the tight fit made for a very sturdy device with easy access to the batteries; which is important since the batteries are constantly being replaced.
Since the cells in a 4 AA battery holder are connected in series this results in an output voltage that can vary from about 4.8 volts to about 6.75 volts (for fresh batteries) depending on the type of AA cells used. The input voltage range of the MintyBoost is about 2-5 volts. So modifying the 4 AA cell battery holder to connect the output of 2 serially connected AA batteries together in parallel would result in about 3 volts for the MintyBoost input voltage but at twice the power capacity. The extra power capacity comes in handle with the power-hungry USB devices of today.
This battery holder modification is the primary subject matter of this instructable. I will also show how the modified battery holder and the MintyBoost are installed into the Altoids tin. Actual construction of the MintyBoost kit is not covered.
Thank you for all the great comments and feedback!
If you're interested in buying one of these completed kits they are now available here...
bit.ly/dh15cJ
Remove these ads by
Signing UpStep 1Tools and Materials
1 - Minty Boost (Available here: bit.ly/bHPSKI)
2 - 1N5817 diodes (Available here: bit.ly/c56Ymv)
1 - Altoids mint tin (about 3.75 x 2.5 x .8) any flavor
1 - 4 AA cell battery holder
There are a number of sources for 4 AA battery holders. I used one from Jameco Electronics and it's shown in the images below. It costs about a dollar and includes a square of foam tape that comes in handy when mounting the holder in the Altoids tin. (Available here: bit.ly/9eOZlI)
22 Gauge stranded hookup wire (red & black)
Solder and related tools
Fairly hefty diagonal cutters
Stuff to insulate wires (Heat shrink tubing and related tools / Electrical tape)
1 wide double sided foam tape
Tools to cut thin, soft metal (Rotary tool and bit, small metal files)
You would need a switch, an LED, LED mounting hardware and a resistor that you can fit in the case. There is not much room available so you may have a hard time finding the right parts to meet your needs. There is no need to remove the battery power from the MintyBoost since it draws very little power in its' idle state. I believe it would take about 10 years to drain the batteries if you never used it. So your LED circuit can just simply tap into the positive and negative battery leads for power.
Since I don't have the components that you want to use I would not be able to create step-by-step instructions. Part of the fun of making things is the experimentation. Why not play around with what you have and see if you can create something that works for you? Then you can create your own instructable and share what you've learned with others. If you don't know where to start then try searching the web for projects that do something similar to what you want. I seem to remember seeing a MintyBoost with an LED flashlight somewhere but I don't remember exactly. It may have been on Instructables.
I am not an expert on solar charging so I would feel uncomfortable advising you. But there is plenty of information on the web. A Google search will return lots of helpful information. To get you started, here is information on a cool solar MintyBoost that you can build from parts available from Adafruit Industries...
http://www.adafruit.com/blog/2010/07/09/how-to-make-a-solar-mintyboost-a-solar-power-charger-for-your-gadgets/
Thanks so much for such a quick reply. I don't really want to purchase more parts(my wallet's slimming down) but I recently found out that I can connect a 12v battery supply to a car charging adapter and it should charge an Iphone. I was wondering if I can use a 4.5v solar cell to charge the 12v power supply in the form of 10 1.2v rechargeable batteries.
Please let me know if this is possible.
Thanks,
Jerry
The good news is I have 2 co-workers who have been using the electronic cigarettes with great results for a few weeks.
The bad news is that the MintyBoost circuit will only output a max of one half of an amp.
Are you trying to create a charger for the battery in the electronic cigarette or an alternate power source?
RoysterBot
Thanks for your prompt reply. I am trying to make it as a power source. I have the idea from here http://www.e-cigarette-forum.com/forum/battery-mods/106016-how-build-puck.html
If I can make it 3 amp with variable voltage from 3-7 volts, it will be perfect!!
Do you know of someone who can make it and sell it to me?
Thanks
Thanks
The MintyBoost USB charger will work from any DC power source in the range of 2 - 5 volts. So your cell phone battery will probably work fine. I am not familiar with LI-ion charging so I recomment that you disconnect the battery from the MintyBoost before charging. I don't know a source for cell phone battery holders.
Best Regards,
RoysterBot
Forgot to mention, This is a very nice and polished "ible, Excellent job.
I 've built the charger but after a while it gets real hot. However the iphone is charging.I used the 1N5818 diodes instead of the 1N5817, because I couldn't find them. Could this be the problem? Apart from that, I measured the voltage of the data pins of the usb port and found out that both give approximately 3 Volts instead of 2. Can you help me please?
Best regards
The Mintyboost does get very hot. If you are charging the iPhone successfully then things sound like they are working normally.
To help dissipate some of the heat I make a small solder connection between the top of the USB connector and the case. I would also like to add a heat sink directly to the 8 pin chip but have not done this yet.
I was originally concerned about how hot the device got while charging but this has never been a problem in the two years I have been using it.
Best Regards,
RoysterBot
I have used this with both version 2 and version 3 of the MintyBoost.
Thanks
a jewel thief would be able to keep running till acid started leaking from the battery's where as this will die when they battery's are about 1v so i little less then most electronics but still not a joule thief. i don't see a real jewel theft being any good though as the battery has already given up most off its power at this point and probably wouldn't charge a phone/ipod
"few tenths of a volt drop" you make it sound like a low number. forward dropping voltage off the ones you linked is 0.45v which is still a considerable amount.
personally iv never had a problem with mixing battery's and i wouldn't put them in
but you have a valid point so that's up to you
tell me why did you not wire the battery's in series?
you could also avoid the diode problem by just having 2 battery's running and 2 in storage.
i ment why not all the battery's together in series giving 6 or so volts
i cant find what chip its based on but iirc it can take 6v and would allow you to squeeze more out off your batts and would be more efficient
