Step 15Final inspection
As you can see in the first two images below the battery holder fits tightly under the inside rim of the Altoids tin. This helps hold the battery holder in place. You can also see in the second image an example of using JB Weld to hold the modified terminal (from step 8) in place.
The last image below shows the completed project. Since we are using a battery case very similar to those encountered in many consumer electronics the double capacity MintyBoost has a familiar feel to non-technical users. This was an important design consideration since most of the people I have made these for are not technical. After installing batteries and closing the tin case the device has a very sturdy feel. You might even say that it's "Curiously Strong".
I'm not sure what it is about Altoids tins. But when people see something useful made out of one they seem to get a real kick out of it. And I get a kick out of making them. I made a bunch of these for Christmas gifts and have given some to fellow volunteers who rely on portable power sources.
Thanks for taking the time to read my instructable. Your comments are welcome and an honest rating would be appreciated.
Special thanks to Lady Ada ( www.ladyada.net ) and adafruit Industries ( www.adafruit.com ).
Thank you for all the great comments and feedback!
If you're interested in buying one of these completed kits they are now available here...
bit.ly/dh15cJ
a jewel thief would be able to keep running till acid started leaking from the battery's where as this will die when they battery's are about 1v so i little less then most electronics but still not a joule thief. i don't see a real jewel theft being any good though as the battery has already given up most off its power at this point and probably wouldn't charge a phone/ipod
"few tenths of a volt drop" you make it sound like a low number. forward dropping voltage off the ones you linked is 0.45v which is still a considerable amount.
personally iv never had a problem with mixing battery's and i wouldn't put them in
but you have a valid point so that's up to you
tell me why did you not wire the battery's in series?
you could also avoid the diode problem by just having 2 battery's running and 2 in storage.
i ment why not all the battery's together in series giving 6 or so volts
i cant find what chip its based on but iirc it can take 6v and would allow you to squeeze more out off your batts and would be more efficient
