Step 11User photo gallery
They look fantastic and I'm thrilled that you took the time to share!
All Steps Viewing
. Will make one soon ! Made one in the past with threaded pipe and put a 90 degree elbow on the end of the pipe. Then put a 12 inch nipple another 90 elbow and an other 6 inch nipple. This makes a crank for your drum.Would have to figure out some way to hold pipe to drum for your idea to be able to turn it ! The one I made used flanges to mount the pipe on a steel drum and the pipe did not go through the drum.
I like your idea a LOT better. (But a crank would be nice.)
Thanks!
Thanks for your interest and your kind words.
1. The process varies by the volume of waste being composted and by temperature. I'd imagine that in Brazil, your climate would be very conducive to composting and you could have a finished batch within a few months. The opposite might be true in Alaska, for example.
2. Yes. Excess liquid will drip from the drums as your organic matter decomposes. I collect it with rectangular plant pots under the bottom drum. I have also seen a very inventive method of collection using gutters and pipes to drain the liquid into a jug. However, I couldn't read the instructions of how they did it because the website was in Portuguese, but the photographs were good enough.
3. Iron drums will rust. I would not use one.
4. The key to making good compost is to allow fresh air to flow in and around the compost. I made several hundred holes in the drums, but they were small to prevent compost from falling out of them.
-Don-
