3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Double-Decker Drum Composter
Step 4The barrel poles
The barrel poles
I used galvanized poles left over from another job and cut two 5 foot lengths. These go through the holes in the posts and are what holds the barrel.
Be careful when selecting poles, since they will need to be strong to support the weight of the barrels when they're full.
13 comments
Mar 7, 2011. 9:15 AMSGravel says:
A PVC "sleeve" around any type of metal pipe would solve the problem of potentially leaching contaminants into the soil. It’s an extra step, but you’ll get the best results combining the two materials.
Apr 25, 2011. 3:41 PMleander37 says:
Oddly, PVC may be more "toxic' than any metal that might be used. Steel is predominantly Iron, which is generally beneficial in soils.
Jun 6, 2010. 6:58 PMperldrivr says:
If people are worried about galvanized pipe, just use the equivalent size black iron pipe, bonus - it costs less!
Apr 9, 2009. 4:13 PMvooodooo says:
what about pvc pipe? is that okay
Apr 10, 2009. 8:14 PMvooodooo says:
do things compost quicker in these barrels than in a compost pile that is turned with a ptichfork?
Apr 23, 2010. 12:34 PMWVSundown says:
The tumblers do make compost much faster!
Apr 23, 2010. 2:14 PMtyanger says:
I've heard that you could compost just as fast with a traditional pile/bin if you turned it as often as you would a tumbler.  That's the catch and the key point though - a tumbler is so much easier to turn that you are pretty much guaranteed to turn it more than you would a traditional pile so it ends up composting faster.
For example, my tumbler is next to my garage so I turn it almost every morning right before I get in my car to go to work (and sometimes after I get home too).  Before I finished the project I was collecting waste in a large Rubbermaid plastic box with holes drilled in it, and realistically I was turning it 1-2 times a week with a pitchfork.  Of course, I would bury fresh waste as it was added, but a really thorough toss ... not very often.
However, I'm a noob and only just recently started experimenting with composting. (Actually, on reading some of these other posts - am I turning it too often?)
Apr 23, 2010. 8:01 PMWVSundown says:
You're absolutely right about the bin vs the tumbler, it's the ease of use that make the tumblers compost faster. I've been composting for 30+ years and I don't think you can turn the compost often enough.
We added 3 fins (3/4" x 3/4" x 24" aluminum angle) to the inside of the barrel to keep the compost from sliding along the barrel wall during turning. It also slings the debris into the axle and helps break it up more. However, this feature creates a kick-back action when the debris hits each fin.
Apr 4, 2008. 3:25 AMpjgardens says:
I thought that galvanized pipe was was a no-no. Is there anything else that can be used?
Apr 27, 2009. 10:17 AMsedona007 says:
why is galvanized pipe a "no no"?
Apr 4, 2008. 8:05 AMpjgardens says:
I think it's a great design, takes the best of everything and makes it simple. Was just curious about galvanized.
Apr 6, 2008. 6:34 AMred_metallic says:
There is an issue with food storage if it is acidic in galvanized vessels. There is also an issue with the lead-based solder used to hold together buckets, etc. as it can leach out and be absorbed by food. In your application though there is likely little contact with the pole and there is no solder involved.
Jun 3, 2009. 4:42 PMbassmasta1010 says:
hey genius, this is a COMPOST BARREL!!! It doesnt matter about "food storage", and "acidic gavanized vessels"........ freakin genius
Mar 30, 2010. 9:32 PMarkbuchman says:
it does matter about food storage because most people put their compost on vegetables, which become food. as plants grow they have to adsorb nutrients from the soil, so whatever is in the soil will get into the plant. so i think this is an important, and i would like to know of an alternative if there happens to be one
Apr 9, 2009. 4:14 PMvooodooo says:
is pvc okay?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:iPodGuy
Just your average handyman.
