Double Sized Ultimaker + , Steel Frame
4,836
82
9
Posted
Introduction: Double Sized Ultimaker + , Steel Frame
I was thinking to make a 3d printer myself, and I never made one before. But I thought it would be nice to make something different. I came up with the idea to make a printer with a steel frame, because steel is cheaper than aluminium and I've never seen a steel printer in this size. After all it was a lot more diffecult than i thought it would be, though I learned a lot from this project.
Step 1: Cad Drawing
I started to draw the printer in Solidworks, I used the dimensions from the UM2 and calculated what the dimensions would be if I made a double bed , I also made z axis with a maximum of 30cm distance.
Step 2: Sawing the Steel Tubes
I bought 6 meters square tube (40x40x3) at a local store , it was about 20 euros. Then I sawed them the right length and I also drilled the holes to later assemble the bearing blocks.
Step 3: Welding the Frame (and Gave It a Color)
we started to weld the frame by making to sub frames and later connect them with the the short tubes (first picture) we checked multiple times if everything was perpendicular, the we welded all together. I finished the welds with a angular grinder for a smooth look. The day after I primered the frame and sprayed it blue.
Step 4: Assemble Some Parts on the Frame
I ordered these parts on ebay and when the arrived I assembled themon the frame
Step 5: Making Some More Parts
I made some parts on solidworks and I had them cut out on a cnc router (8mm Aluminium), the sheetmetal I bought at a local hardware store. A friend made the adapters for the z axis on a router, he used acrylic. I also ordered a custom hardened glass plane. (you can see the acrylic adapters on the last picture)
Step 6: Cold End
I made an adapter to mount the nema 17 on the cold end. I laser cutted it out of plywood.
Step 7: Making the Electronics...
A friend helped me to make electronic part of the project, we drilled some holes in the tubes to lead the wires from the top to the bottom. I also laser cutted the 'floor' and later mounted the 12v supply and arduino etc. This is how the printer is now , I need some time to finish it and will upload some photos again when its finished.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    9 Comments
    Please, could you send the solidworks drawings files ?
    This looks awsome - I wonder how much does it weigh?
    Could you please post the SolidWorks plan files here?
    Hello RemyE2
    For us who do not have SolidWorks, would you like to share your drawings with us in PDF or similar.
    Do you have a BOM list of the parts you bought the printer. Both Components and Electronics?
    Wonderful to see such a project made of steel rather than the more traditional aluminum profiles.
    We look forward to seeing it in operation when you have created a little finish on it.
    Nice work
    The total price was about $800, but if I ordered all parts in one package and at the same supplier, I think it would've cost about $650 or maybe less. If I would do it again, I'll go for thicker axles for x and y movement, I think at least ø12mm , because of the stiffness. If you have more questions you can ask me.
    That looks awesome! I really wish I had a 3D printer at home. :)
    Thank you!
