Double Smoked Ham
134,238
71
17
Published
Introduction: Double Smoked Ham
Most hams you get from the store are cold smoked already cooked hams. This will show you how to add more flavor to the ham and smoking it again while reheating it.
Step 1: The Ham
For this you will need a good ham, the better the ham you get the less fat that will be on it. For this recipe I used a 15 lb Hillshire Farm ham, a good rule of thumb is for true indirect, low and slow BBQ, that if it will take you more than 2 hours to cook get a good piece of meat. Why go through all that work for a bad tasting piece of meat.
Step 2: Making the Injectable
First you will be making the injectable you will need
1    Cup    water
1    Cup    light Karo
1/8 Cup   Amaretto Liqueur
4    Tbsp  Real 100% maple syrup
1    Tbsp  Rum extract
1    Tbsp  Orange juice concentrate
1    Tbsp  Vanilla extract
In a medium sauce pan, heat slowly the water, Karo syrup, and Amaretto. Stir frequently and heat very slowly to avoid scorching of the sugars. Once blended add the remaining ingredients and continue to stir. When the mixture has a uniform color remove from the heat and cool to room temperature.
Step 3: Injecting the Ham
For injecting the ham I use a syringe with the holes on the side of the needle not the end of the needle to allow what you are injecting to be spread out more throughout the meat.
Before injecting make sure you place the ham in a metal pan to catch the extra juices from going all over the place.
inject the ham in a grid like pattern on top of the ham every inches.
Once you are done injecting the ham wrap the ham in 2 layers of plastic wrap and place in the refrigerator for 24 hours.
Step 4: Lighting Up the Smoker
Using good lump charcoal is a must, even the lump charcoal gives off a great smell.
I use Weber chimney to start my charcoal. A little newspaper in the bottom of the chimney, fill the top with lump charcoal and 15 minutes later, good to go.
Heat the smoker/grill to 250 degrees for at least hour before putting the ham on.
Step 5: Getting Ready to Smoke
Remove the ham from the fridge and allow it to get close to room temperature.
For wood, you can use wood chips but I use larger chunks of wood they last much longer so less times of opening the cover. For this I am using hickory wood chunks that is soaked for at least an hour.
Place the ham in some kind of rack that it prevents the ham for sitting in the fat that drips off into the pan.
Slit the entire ham to help the fat drip off the ham and to allow the smoke to reach the ham.
Once the smoker is to temperature place the ham on the smoker. Pour apple or pineapple juice under the ham to help keep the ham moist but do not let the juices touch the ham.
I am using a thermometer with a temperature probe so I can monitor the temperature of the ham without opening the lid. For a precooked ham you want the ham to reach 140 degrees.
Place the wood chuck directly on the charcoal.
Step 6: Making the Glaze
While the ham is cooking you can make the glaze for the top of the ham, ingredients you will need are:
1/2 Cup  Brown Sugar
1/2 Cup  Maple Syrup
1/4 Cup  Honey
2    Tbsp Cider Vinegar
1    Tbsp Worcestershire
2    Tbsp instant coffee grounds
1    Tbsp dry ground mustard
2    Tbsp orange juice concetrate
Mix in a sauce pan and slowly heat it, once blended set to the side. (You might need to reheat it a little bit before putting it on the ham)
Step 7: When to Add the Glaze
After about an hour and a half rotate the ham a 180 degrees so the ham heat consistently.
After about an hour after rotating it, take and instant read thermometer and check the temperature throughout the ham. Once the ham has reached about 130 degrees it is time to apply the glaze. Apply half of the it then wait 20 minutes and apply the rest.
Step 8: Slice It Up
Check the ham for a consistent temperature of 140 degrees throughout the ham. Once the ham has reached 140 degrees remove it from the smoker.
Let the ham set for at least 15 minutes before slicing it.
I use an electric slicer to cut ham, to me it seems like it gives me consistent size slices.
With this ham being injected and not overcooked the ham will remain juicy.
Next time you will want to cook 2 hams, one fore you and one for everyone else.
BBQ Contest
Grand Prize in the
BBQ Contest
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    17 Comments
    I made this exactly to the ops recipe specs. This was by far the best glaze I have had on a smoked ham. I wouldn't make it all the time because of the cost factor for the ingredients, but I will for sure at holiday times. I made it this past year for Thanksgiving 2015
    Why not put the foil drip pan under the cooking grate and just put the ham directly on the cooking grate, above the pan?
    What part of "be positive and constructive" did you not understand? Don't bother answering because you are about to be deleted.
    Are ya daft mate, we're talking intense deliciousness on a par with good nookie, depending on your partner, maybe better!!!
    this looks incredible actually. Ever do it for a fresh ham for slicing or pulled pork?
    I have done pulled pork, Turkey, Brisket, and much more. I am going to keep posting them as I do them. All I have to do is if you cook anything more than 2 hours on a smoker or grill go all out.
    No comparison to good nookie, at least my nookie. I have no idea what your nookie smells/tastes like. Sounds fishy to me. ;-)
    well yeah !!!!! Life is too short for cheap wine, cheap chocolate and lousy food. One must take time and do the slow life. This is something you do and wait , with a nicely brewed iced tea or homebrewed beer or jug of inexpensive NOT cheap wine and your favorite squeeze. (you choose the beverage and the squeeze. Heven help you if squeeze A finds out about squeeze B. YIKES ;-) hey that picture looks like some of my relatives baby pictures, heck for some wedding pictures as well.
    enjoy
    no such thing as too many and too much if it is worth it in the end.....
    This is great. If you use an electric smoker it is a lot more easy. You use wood chips and get GREAT tast
    Because you injected the ham with a sweet sauce and then glazed the ham with more sugar the ham bone won't make a very good pea soup IMHO. I've made ham soup with a store bought ham that had been cooked with the glaze that came with it and the soup was way too sweet. The spices and sugar overpower the ham bone and gives the soup a strange flavor to me. Then again I don't like sweet ham. If I had the means I would just smoke the ham without the added syrup and sugar.
    Very nice job on the instructable!
    I was not too sweet at all, it was a great mix of not sweet things and the sweet ingredients.
    Buy a cheap ham for the soup. This one's for eatin'! (-:
    This looks awesome. Now I just need to get a BBQ/Grill like what you have. I just have a standard Weber bowl grill.
    That is one beautiful ham! Nice job!
    That rack looks just like the one I saw on America's Test Kitchen, it's also a rib rack. If you don't have a rack, you can use a big snake of aluminum foil and shape it to elevate the ham.
    I'd get up in the middle of the night to have some of that.
    Looks scrummy.
    Definitely on my to-do list.
