Double Voltage of your one AA Battery device
 by dragonbtv
A very simple method to get double output voltage within the space of a single AA battery. Useful for strengthen your single battery powered device, eg. flash light, nose hair trimer and etc.
Step 1: Reason
Sometimes you are not satisfy with the POWER of your single battery powered device, such as your dim tiny flash light, tooth polisher or the MOST common used nose hair trimmer.
For me, I have changed a lot of them but they are all slow even when I use a NEW battery.
Each time I used them I sweared to put TWO batteries inside it someday.
badams2 says: Nov 12, 2012. 8:57 PM
You could possibly break the seals (or the battery casing itself) on the batteries doing this, causing leakage and ruining your devices.
ossumguywill says: Jan 22, 2010. 10:15 PM
doesn't everyone realize you could just get some 14500 batteries? up to 4.2V in a rechargeable AA size thing. No hacking needed.
gear-guy says: Aug 29, 2009. 12:48 PM
in the uk the batteries inside a duracell 9v are red,even though tey look the same on the outside.
james.mcglashan says: Apr 4, 2009. 11:22 PM
y not put the batterys in parralel so u still have the 1.5 volts and u have longer living batterys in the end and put it in an old battery after taking everything out of it.
Herminator in reply to james.mcglashanApr 12, 2009. 8:34 PM
Because he wants it to be more powerful not longer lasting, so he puts 2 1.5v batts to double the power (3v). Get it?
james.mcglashan in reply to HerminatorApr 29, 2009. 4:48 AM
yes but if u blow up the torch not my proplom. and if u use it in parralel u can get longer lasting and brighter for longer... am i not correct..????
Herminator in reply to james.mcglashanApr 29, 2009. 11:41 PM
Yes you could put the batteries in parallel but thats not the point of this ible, he wants more power not longer lasting... And you could blow out the bulb but its not going to "Blow up"... i thought you were talking about the trimmer :P btw its problem not proplom...
james.mcglashan in reply to HerminatorApr 30, 2009. 11:15 PM
btw i hate spelling and i ment blow not blow
Father Christmas in reply to james.mcglashanJul 7, 2009. 12:53 PM
"blow not blow " Umm. I think I may be missing something here...
YoChuck says: Dec 23, 2008. 10:44 AM
Very nice instructable. Not that I'm not a fan of hacking things up, but I did want to point out another alternative if anyone's interested in going the 'double voltage' route. Lots of battery websites like all-battery.com offer rechargeable Ni-MH batteries at 1/3 and 2/3 the size of a standard AA. A combination of the two would produce one AA-size battery rated at ~2.4v. This can come in handy for those tight spaces where you'd want to increase the voltage! Again, great instructable!
dragonbtv (author) in reply to YoChuckDec 23, 2008. 11:31 AM
thanks for your info! special battery for flashlight is very POWERFUL too!
frollard says: Dec 7, 2008. 5:10 AM
Awesome project - As for 'the best trimming experience'...just wait till that little sucker grabs your sinuses and rips them out your head :D Good job!
Magnelectrostatic says: Dec 5, 2008. 5:31 PM
Your not actually doubling anything, that's kind of annoying.
socrateez in reply to MagnelectrostaticDec 5, 2008. 6:27 PM
He's doubling the voltage out put to the motor. 2X the rpm at the sacrifice of some run time and a little lower max amperage. I may try this as my trimmers lack a little speed Those "babies" are AAAA batteries. I have a pen light that takes them. this is where I source my batteries for it as AAAA's are about as expensive as AAA's if not more.
Magnelectrostatic in reply to socrateezDec 6, 2008. 1:21 PM
I meant he's not actually "doubling the voltage of an AA battery" he's just using more batteries, that aren't AA's.
pudicobar says: Dec 5, 2008. 4:59 PM
Damn it. I lost the contest. You won... :-(
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
