Rev 6.- A Gun In Each Hand.
 by Attmos
  Most nerf guns require the use of two hands, one on the trigger and one to cock it or pump it up.  With a simple attachment to the cocking mechanism, turn a two handed weapon into a one handed weapon; freeing up your other hand to hold another weapon.  It should be noted that, while you can cock a gun one handed by pressing the mechanism to your hip and pushing the gun downward; if you have a stiffer spring, or two springs as my gun does, cocking your gun one handed is almost impossible without this strap, for me anyway.
Step 1: Materials
- nylon strap (the kind found on a backpack)
- strap clips (found on the straps of a backpack)
- about 6" of small chain or cord (rope)
Step 2: Arm Strap
Measure enough strap to circle your bicept with a couple extra inches.  Attach the clips on either end, so that you have a snug fitting strap that clips and unclips from your bicept.
Step 3: The Chain
Connect the chain or cord from the loop on the back end of the cocking mechanism, to your arm strap.  it should be just a little loose while your arm is bent.
DSJesterXII says: May 27, 2013. 4:37 PM
That's sexy.
X#01 says: Aug 10, 2012. 9:46 PM
Did you use a crutch to make that gun
Attmos (author) in reply to X#01Aug 10, 2012. 11:40 PM
Ha Ha, Yes, good eye. I found that the tubing on an old set of crutches I had, were of perfect diameter and shapes for what I wanted to do.
X#01 in reply to AttmosAug 12, 2012. 11:51 PM
Genius
MAVREV13 says: Mar 4, 2012. 8:48 AM
may i ask how far your shooting?
in feet, my guess is 20 to 25
Attmos (author) in reply to MAVREV13Mar 4, 2012. 9:37 AM
it has all the internal mods
MAVREV13 in reply to AttmosMar 4, 2012. 10:05 AM
nothing agenst you but you didnt answer my question, personally and from other modders they say the longer the barrel the more your range is going to be hurt
Attmos (author) in reply to MAVREV13Mar 4, 2012. 8:02 PM
its just for fun dude. i don't use it on the field like you do.
MAVREV13 in reply to AttmosMar 9, 2012. 7:46 AM
i know, im curious with what all has bin done because the maverick is kinda low on modding ability so when i hear a new maverick mod i get qurious
black hole says: Feb 20, 2012. 12:20 PM
Fantastic job. 5*
Attmos (author) in reply to black holeFeb 20, 2012. 1:14 PM
thanks, glad you like it. hope it helps in your next battle.
Haplo1 says: Feb 11, 2012. 12:47 PM
ha ha ha. You Suck! Thats so good! My Recon AR is looking pretty good. my maverick needs some work. i voted on the disc baskett. (this is Pete by the way)
conkay119 says: Feb 5, 2012. 8:32 AM
how does it double ur fire power? did u mean it allows u to shoot faster?
Attmos (author) in reply to conkay119Feb 5, 2012. 10:15 AM
you can use two guns this way, one in each hand. the title is kind of misleading, sorry, i'll change it.
conkay119 in reply to AttmosFeb 8, 2012. 2:26 PM
oh ok cool thanks. I love all these kinds of nerf vids and i already made this. thanks!
Attmos (author) in reply to conkay119Feb 8, 2012. 3:43 PM
glad you like it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
