Yes.
I like this new weapon.No exotic or modded pieces
Pros:
It's a shotgun
you don't have to load in bullets every time you want to use it
(unless you didn't build the magazine version)
Cons:
Very little space in-between trigger mech and ammo.
Not a very gun-like magazine
Cannot chose whether to fire one shot at a time, both shots are fired.
Changes from initial design:
Added removable mag which is also kind of like an extension barrel. I would call it a 'clip-on' mag.
Fires different ammo.
come on, you NEED to look around at what other people have done before you post stuff like this. and give all the damn cons.
it's possible i have used some b4, but don't know the names of them.
you know the thing which pushes the bullets up into the gun?thats called a mag pusher. Integrated mag pushers, are where the mag pushers are inside the gun, not big jerky blocks sticking out of the side.
www.instructables.com/id/Desperodo
sometime soon, I hope?
Here, the longer the time the pin has to accelerate before it hits the bullet, the more powerful the shot will be. How much knex do you have? if you have enough, build the untangle. its the most powerful knex gun ever made. gets 450ft. Just remember to use finned ammo.
http://www.instructables.com/id/Knex-Through-14-Wood/
Oddammo is a red connector stuck to a rod, right?
If not, then what is Oddammo? (ood? odd?)
