Step 4: Glue and insert flash drives
Now it's just a matter of applying glue, I used Elmer's® Carpenter's® Wood Glue, clamping it and letting it dry.
The fit was so snug that I just pushed the drives in and they're staying put. If it's a little loose you can easily dab a bit of hot glue onto the end and the sides of the drives and use that to keep it in place.
So now you have a double-ended flash drive. Carry your digital life around with you and take on everything.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
