loading
With a handful of parts, a solder iron, and about an hour, you can double the range of your TV-B-Gone (R) universal remote control.
TV-B-Gone remotes work great to turn off TVs anywhere you go. But they work even better when they have more power.
We will be adding one more IR emitter to a TV-B-Gone remote, and powering the resultant two IR emitters with larger batteries than the small coin cell battery in the stock TV-B-Gone.
(There is also a more complex yet Ultra High Powered TV-B-Gone Instructable.)
This Instructable grew out of workshop that I did at 23C3, the hackers conference in Berlin in December, 2007. FoeBud, a German organization that educates the public about privacy issues with technology, let me use their workshop bench to teach people how to solder, using this project as an example.
Thanks to Rena Tangens, of FoeBud, who took all the photos.
Step 1: Materials and Tools
Parts:
A -- TV-B-Gone (1)
B -- 940nm IR emitter (1)
C -- Battery Holders that holds two batteries (2)
D -- Batteries (4)
E -- Solder
Tools:
F -- Solder iron
G -- Small Phillips screwdriver
H -- Needle nose pliers
I -- Diagonal cutters
Not shown:
-- Wire, several inches of two different colors
-- Wire stripper
-- Solder Wick (or a Solder Sucker)
This photo has Notes -- roll the mouse over the parts with squares to see these important notes.
Step 2: Take apart TV-B-Gone
Unscrew the small Phillips screw on the back of the TV-B-Gone. (See 1st photo.)
Take off the back. (See 2nd photo.)
Take the PCB out of the plastic housing. (See 3rd photo.) (PCB stands for Printed Circuit Board -- it is the board that all of the components are soldered to.) Your modified TV-B-Gone will not fit into the cute batman-like keychain after you are finished, so please recycle or re-use the plastic and metal pieces for some other project.
Take the battery out of the battery holder marked B2. (See 4th photo.) Save this battery, as we will need again later.
Take the battery (or batteries) out of the battery holder marked B1. (See 5th photo.) This battery (or batteries) will not be needed for the modified TV-B-Gone, so please re-use or recycle.
Step 3: Prepare Battery Holders
Cut 1 1/2" of wire (I used red) and strip 1/8" off of each end. Solder it between the positive terminal of one battery holder and the negative terminal of the other. (The negative terminals of the battery holders are the ones that look like springs.) (See 1st photo.)
Cut 4" of one colored wire and 4" of the other colored wire. Strip 1/8" off of each end of each wire. Solder one wire (I used Red) to the unused positive terminal of the battery holder and the other wire (I used Blue) to the unused negative terminal of the battery holder. (See 2nd photo.)
The result is that when the batteries are installed in the battery holders, there will be 4 batteries in series, making 6 volts to power the IR emitters.
Step 4: Prepare original IR emitter
Unsolder the IR emitter from the PCB. To do this, hold onto the plastic part of the IR emitter with your fingers of one hand and pull gently, while using you other hand to melt the solder pads on the PCB with a solder iron. You will need to go back and forth, first melting one pad and pulling gently, then melting the other pad and pulling gently, then back to the first, etc., until the emitter comes out. (See 1st photo.)
Use Solder Wick (or a Solder Sucker) to open up the two holes on the PCB for the emitter. You should be able to see through the two holes. (See 2nd photo.)
Bend up the negative lead of the IR emitter as shown in the photo. (See 3rd photo.)
Solder the positive lead of the IR emitter (the one you did not bend up) into the pad marked "+" as shown in the photo. Now the IR emitter is in the same position it was in originally, but with the negative lead bent up. (See 4th and 5th photos.)
Step 5: Install 2nd IR emitter
IR emitters come with one lead longer than the other. The longer lead is the positive lead and the shorter lead is negative. (See the first photo.)
Bend up the negative lead (the shorter lead) of the IR emitter as shown in the 2nd photo. There should be about 1/8" of lead sticking out from the emitter before the bend (as you can see in the 2nd photo).
Push the negative lead (the one you just bent) into the empty emitter pad on the PCB and solder it. Be sure to solder it on the opposite side of the PCB from the original IR emitter. (See the 3rd photo.)
Clip the excess lead that sticks up through the PCB. (See the 4th photo.)
Bend the positive lead of the new emitter around as shown in the 5th photo.
Continue bending the positive lead of the new emitter around the bent up lead of the original emitter as shown in the 6th photo.
Solder this connection between the positive lead of the new IR emitter and the negative lead of the original IR emitter. Then cut the excess lead. (See the 7th photo.)
Step 6: Attach batteries
Solder the negative wire (I used blue) from the battery holders to the pad on the PCB shown in the 1st photo.
Solder the positive wire (I used red) from the battery holders to the pad on the PCB shown in the 2nd photo.
Insert the 4 batteries into the battery holders, making sure the negative of each battery is at the spring in the battery holders, as in the 3rd photo.
Insert the CR2032 coin cell in battery holder B2 on the PCB, with the side marked "+" facing out. (See 4th photo.) Do not insert any coin cell batteries into battery holder B1 on the PCB.
As soon as you insert the coin cell into B2, the visible LED on the PCB will blink (see 5th photo) -- 6 times for European database, or 3 times for North American database (see Step 9 for changing between North American and European databases). If it does not blink, then there is probably something wrong with the voltage from the new battery holders you added (see the next step, Step 7, for testing & debugging tips).
See the 6th and 7th photos for two views of the finished high-power TV-B-Gone.
You can use your High Powered TV-B-Gone as it is, or you can put it in a new case (it won't fit in the original, cute batman-like case any more). Some people have used a cigarette box.
Step 7: Testing and Debugging tips
The IR emitters emit very bright light! But the light they emit is invisible to our eyes (IR stands for Infra Red, which means that its frequency is below visible red light). IR remote receivers in TVs can "see" IR, and so can digital cameras.
To test your new high-powered TV-B-Gone you can point it at a TV, push the button on the TV-B-Gone, and keep it pointing at the TV until the TV turns on or off. To test it more thoroughly, push the button on the TV-B-Gone and point it at a digital camera -- if your high-powered TV-B-Gone is working you will see the three blinking lights on the camera: the visible LED, and both IR emitters (even though you will not see the IR emitters blinking with your eye).
If the visible LED didn't blink when you inserted the coin cell into B2, or if both IR emitters do not blink when viewed with a camera (and you can't turn a TV on or off) then you will need to debug the circuit. There are only two areas that can go wrong: the voltage from the new battery packs, or the orientation of the new emitter.
If you have a volt meter, measure the voltage where the wires from the battery holders are soldered to the PCB -- is there 6 volts, with the correct polarity? One of the battery packs I bought at Conrad in Berlin was defective (they are made pretty cheaply), so I had to replace it.
If the voltage is OK, the only other problem could be with the IR emitter -- maybe it is a freaky one with the polarity reversed (one that I bought at Conrad in Berlin had the negative lead longer than the positive lead, unlike any LED I had ever encountered before). If so, then remove the new emitter, reverse it, and test again.
Step 8: Use it!
Go out into the world and enjoy the satisfaction of making it a better place by turning off TVs everywhere you go.
Step 9: North American vs European TV-B-Gone
Since there are so many different makes and models of TVs around the world, with hundreds of different POWER codes, TV-B-Gone has a different database for Europe (EU) and for North America (NA). The NA model also works well in Asia. TV-B-Gone determines whether to use its EU or NA database by looking at the jumper in R5 (see the red circle in the photo -- the photo shows an EU TV-B-Gone). R5 can be anywhere from 0 ohms through 15Kohms. If the jumper across R5 is present then the TV-B-Gone uses its EU database. If the jumper is absent it uses its NA database. You can change your TV-B-Gone from one to the other by removing or adding the jumper (but please remove all of the batteries while soldering). Some people have installed a small switch to make it easier to change between databases.
Step 10: Schematic diagram
Although you don't need it to follow the previous steps, here is a schematic diagram for those who want one.
I really want to make one of these, but I'm bad at soldering. Do you have any tips? On a less related note, would a lens array work to increase range even more?
Wow, great idea sami. It would be cool to have one of these dressed up like a flash drive powered by the usb port. People would think you were fidgeting with your port on the computer. :)
Nice tutorial but I'm wondering if it's possible to replace your AA batterie with a 5V USB port .I mean that I want to power up the TV B Gone with my laptop.?
You can power with USB from your laptop, but depending on your laptop's USB port, your computer may limit the current it sends out its USB port, so it may be less powerful than using two AA batteries.<br><br>Try it and see.<br><br>Mitch.<br>
that`s funny. i listend to an older ccc podcast (24C3 2214 - Make cool things with Microcontrollers - Hacking with Microcontrollers) a few minutes ago and stumbled upon this tutorial.<br><br>thank you for putting this useful tutorial guide on.<br><br><br>
Sure! Happy hacking! And, please turn off lots of TVs! <br> <br>Cheers, <br>Mitch. <br>
A word to the wise: The TV-B-Gone does not just work on TVs but almost any device that uses IR communications. I discovered this by accident when I decided to try mine on a TV in the room and accidentally caused the my roommate's iHome stereo to play music loudly. I regret not trying this for April Fool's Day.<br />
Thanks for pointing this out.&nbsp; <br /> <br /> A more accurate description:&nbsp; <br /> TV-B-Gone remote controls have only TV POWER&nbsp;codes in its database.&nbsp; There are actually very few devices that will respond to these codes besides TVs (in the over 5 years of using and selling TV-B-Gone remotes I've only heard of a handful of cases where a TV-B-Gone has had any effect on devices other than TVs (most of them are for one&nbsp;company -- I can't remember which --&nbsp;that uses the same POWER&nbsp;code to control their DVD&nbsp;players and their TVs).<br /> <br /> Mitch.<br />
My TV-B-Gone turns on the LED lamp in my room, which uses an infrared remote. http://www.thinkgeek.com/gadgets/lights/831e/
Cool. That lamp probably uses a pretty simple IR encoding scheme, and so might have a few false triggers. I'm curious -- does it also respond to other TV remote controls? Does the TV-B-Gone make your lamp go through lots of nice colors? Mitch.
Actually, no. It always turns on right after the fifth code, and none of the other ones do anything to it. No TV remotes in my house affect it. I'm guessing they didn't make sure the on/off signal they used wasn't the same as a TV's. It would be really annoying if you had it in the same room as the TV with the code that triggers it...
The 5th code is for Philips TVs. So, for whatever reason, they used a Philips on/off toggle code.
That's odd.
I stand corrected! I guess the TV-B-Gone doesn't mess with the majority of IR communication systems. However, I still regret not using it for April Fool's Day.
Recycling Generator
Im using 6 IR Leds&nbsp; and I soldered led like this +- +- +- +- +- +-<br /> positive to negative and so on...<br /> I did same as u did but doesnt work, Only I know its ON because little red LED is blinging<br /> Help me ASAP plz<br />
I made a comment after yours on the Batteries page, but I'll comment here, too:&nbsp; to use 6 IR&nbsp;LEDs you need more voltage -- 3v per LED.&nbsp; So, for 6 LEDs you need 12 AA&nbsp;batteries in series for B1. &nbsp;(But be sure to keep B2 at 3v, since&nbsp;B2 is for the microcontroller.)<br /> <br /> Mitch.<br />
It works. Nice job. I made one 5 min ago. The IR sems to be stronger or something now!
Yes, the IR&nbsp;is twice as powerful with two IR&nbsp;emitters and the bigger batteries.&nbsp; Please turn off lots of TVs with your new power!&nbsp; :)<br /> <br /> Mitch.<br />
Hi, I made exactly what did u showed us. <br /> It dont work ??<br /> What I did wrong I putted 6 IR Leds but when I measured there doesnt come any Voltage to the leds ??<br />
It won't work with 6 IR LEDs unless you use a more batteries.&nbsp; Each LED needs 3v to function, so if you want 6 LEDs, you will need to put them in series with each other, and then use 12 AA batteries in series with each other (for B1).&nbsp; But make sure that you keep the B2 battery the same, since this powers the microcontroller, which can only function with voltage between 3v and 5v.<br /> <br /> Mitch.<br />
How meny nm is the IR-LED in a TV B-GONE. Can you change the IR-LED&nbsp;without any other stuff that you have too change.-
TV&nbsp;remote controls all use 940nm.&nbsp; If you use any other wavelength, it will probably work, but with greatly reduced range.&nbsp; The IR&nbsp;emitter I&nbsp;use for TV-B-Gone is made by Everlight, part number:&nbsp; IR333/H0/L10.&nbsp; You can get it at Mouser.com -- here is the part number for Mouser:&nbsp; 638-IR333/H0/L10.&nbsp; This is the most powerful IR&nbsp;emitter that is available, and it is also really cheap:&nbsp; $0.29 each for 1 piece, in the US (and probably comparable elsewhere).<br /> <br /> If you use another IR&nbsp;emitter, it will work, but the range will be less.<br /> <br /> Cheers,<br /> Mitch.<br />
can u put 850nm vs the 940nm LED currently in the device
1.Watch 2.Do 3.??? 4.Profit!
Can you put a link with the schematic diagram larger, please. With the image I can't read nothing. (Sorry for my english, but I'm learning it) PD Very good this instructable, very nice
I just uploaded a higher-resolution schematic. I have also put it on my Flickr account:<br/><a rel="nofollow" href="http://flickr.com/photo_zoom.gne?id=1980643045&amp;size=l">http://flickr.com/photo_zoom.gne?id=1980643045&amp;size=l</a><br/><br/>Sorry it took so long to update it.<br/>
Sorry for the fuzzy schematic. I can't seem to find my source files for these. I'll have to create them again. Please give me a few days. In the meantime, here's a description of the relevant parts of the schematic: The IR signal from the microcontroller comes from pin 12. That goes through a 120 ohm base resistor into the base of a 2N3904 transistor. The transistor's emitter is tied to ground. The collector goes to the cathode of the stock IR emitter (which is an Everlight IR333-A), and the anode of this emitter goes to the cathode of the added IR emitter (same as the stock emitter, available at Mouser.com, part number 638-IR333-A). The anode of this added IR emitter goes to +6v (which comes from four AA batteries). Be sure to remove the battery (or batteries) that are in battery holder B1 of the TV-B-Gone, and do not use these together with the four AA batteries.
Hmmm now if only there was a way to focus these beams into a longer range system so either an IR based laser pointer (no idea if that would work at all) or possibly a couple of lenses or something similar to give superlong range and accuracy
I've also been thinking of using an IR laser to get super-long range. What troubles me is making it safe -- a highly focused laser beam that momentarily reflects off of a shiny surface might permanently damage someone's eyesight. If the beam were difussed a little, however, then it could be safe. Now, how to safely guarantee a difused beam, and how to modulate the laser at the proper frequencies? Also, I'm not sure if there are 940nm IR lasers, which is the IR wavelength of TV remote controls. Laser's aren't really my forte. If anyone knows about this stuff, please let me know.
if you found the laser a piece of slightly brushed glass would diffuse it nicely but i see the dangers involved
Also, a laser will be VERY directional. You'd need to diverge the beam so it has spread. It'll be easier to aim and still have great range. A better alternative is to amply the electrical signal with a fast Darlington and an LED array, like those IR security lights. Or, that "ultra-TV-B-Gone project. I devised something even more wicked: a Cable-B-Gone hat. Cable boxes from one monopoly cable operator are "keyed alike" - they all use the same remote. Hack the code for your town's cable boxes, and have fun! I need to post my remote control hat as an instructable.
Please do post your remote control hat as an instructable! And please post it as a comment here. I'm working on a Super-High-Power TV-B-Gone now. It goes well over 50 meters! I use 6 IR emitters, each with their own transistor driver (PN2222A with a 120 ohm base resistor and no current limiting resistor in series with the emitter and collector, with the emitter tied directly to ground -- this is the same circuit as the emitter and driver for the regular TV-B-Gone), and four AA batteries to power the emitters. I have successfully turned off huge-screen TVs facing out of very thick plate-glass windows, from across a very wide street! Very satisfying. I'll post an instructable about this soon. I'll also have them available ready-made from TVBGone.com later this year.
You can get a 940nm IR laser for 60 USD from digikey.
should i get a Tv b gone or a ninja remote
That's up to you. Of course, I know which one I like -- TV-B-Gone, the way cooler one that works way better, and that isn't in it only for the money. :)
thank u made my mind
thats pretty cool. now if i can just find a tv-b-gone. i'll probably use 3-4 leds all pointed at the same spot though instead of two and a 9-volt battery instead of the 4 AA.
TV-B-Gones are available from many places on the web, including<br/><a rel="nofollow" href="http://www.TVBGone.com">http://www.TVBGone.com</a><br/><br/>Depending on how you do it, using more than 2 LEDs may require some additional circuitry. To keep things simple, you can use 3 IR emitters in series, and use a 9-volt battery to power the emitters. The rule of thumb here is to have 3-volts for each IR emitter. If you want more power, then please check out the Ultra High Power TV-B-Gone Instructable:<br/><a href="https://www.instructables.com/id/ELSIDWXRAFEP2881ZQ/">https://www.instructables.com/id/ELSIDWXRAFEP2881ZQ/</a><br/>
hi greazt job <br/>I have tv b gone like mini remote, do you think i could try to apply exactly or modified trick?<br/>for information <br/><br/><a rel="nofollow" href="http://cgi.ebay.fr/Telecommande-universelle-NESTpas-TV-B-Gone-TM_W0QQitemZ5782021045QQihZ008QQcategoryZ60838QQcmdZViewItem">http://cgi.ebay.fr/Telecommande-universelle-NESTpas-TV-B-Gone-TM_W0QQitemZ5782021045QQihZ008QQcategoryZ60838QQcmdZViewItem</a><br/><br/>thanks<br/>
This same method can work for any TV remote control. But you'll need to be careful about splitting up the power supplies for the microcontroller and the IR emitters -- you don't want to burn out the microcontroller on your remote control.
surely you will only get 40% greater range by adding the 2nd emitter, since the light diverges in 2 dimensions.<br/><br/>what emitter are you using? cant you just use 1 brighter IR LED, like:<br/><a rel="nofollow" href="http://www.fairchildsemi.com/ds/1N/1N6266.pdf">http://www.fairchildsemi.com/ds/1N/1N6266.pdf</a><br/>or <a rel="nofollow" href="http://www.advancedphotonix.com/ap_products/pdfs/PDI-E805.pdf">http://www.advancedphotonix.com/ap_products/pdfs/PDI-E805.pdf</a><br/>?<br/>
After checking into some other IR emitters, I see that there are two better choices at Mouser: Everlight IR333C/H0/L10 and Everlight IR333-A. The first one has an output angle of 40 degrees with 450mW/sr radiant intensity, and the second one has an output angle of 20 degrees with 750mW/sr radiant intensity. I changed the recommended IR emitter in Step 2 of this instructable for the 20 degree emitter: IR333-A.
It actually does much better than 40%. The extra power comes from the bigger batteries. Coin-cell batteries (used in the stock TV-B-Gone) have a high internal resistance, so when using them to power the IR emitters, the coin-cell's internal resistance limits the current that can be pumped into the emitters. AAA, or even better, AA batteries (or even better, C or D) have a much lower internal resistance, so much more current can go through the emitters. And the more the current, the brighter the IR light. The IR emitters that come with TV-B-Gone remotes are the brightest ones I have been able to find (Everlight IR333/H0-A, but these are not easy to get). If you look in Step 1, the photo of the Materials & Tools has Notes that appear when you roll your mouse over the parts with squares around them. Check out the Note for the IR emitter, and it shows the emitter that I suggest using is an Everlight IR323, available at Mouser.com for $0.16 each. The IR emitter needs to have a wavelength close to 940nm, since that is what TV remote controls use. The two emitters you gave datasheets for will work, but I think the Everlight IR323 is probably a better choice. The Advanced Photonix emitter won't work so well since it is 880nm. The Fairchild emitter will work well, but it has an narrower output angle, so you'll need to aim it more accurately. (The cool thing with the Fairchild part is that it can take up to 10A of pulsing current -- it might be really cool to use an array of these pointed in slightly different directions!)
thanks for part number on your IR emitter. besides using more emitters and power, a smaller beam angle seems like a great way to get a lot more distance which is one reason i posted those two emitters. sure you have to aim better, but you get a much longer beam for your troubles since the light is concentrated to a smaller area.
About This Instructable
33,011views
42favorites
License:
Bio: Inventor of TV-B-Gone.
More by mitch:Double the Range of Your TV-B-Gone
Add instructable to:
