Turns out, I was right.
I would harbor a guess that the DX2 (new and old) use the same regulator inside. However, I have not tested those and the innards may be a little different. Check your parts, and make sure your soldering it in the right way. Best case, it doesn't work. Worse case, you release the factory-packaged smoke and you get to buy a new radio. Not fun.
The mod is about as easy as it can get: De-solder a component, tin the pads, put the other component on. Done.
Here's a picture-by-picture diagram on what to do. As with everything on the Internet: I take no responsibility on your actions. This worked for me. It may not for you. Don't do it if you can't solder.
Remove these ads by
Signing UpStep 1Assemble your tools
Phillips Screwdriver
Needle Nose Pliers
Soldering Iron
Solder, sponge, etc.
http://www.dimensionengineering.com/DE-SW033.htm
I plan to solder wires on the lower print at the opposite side of the lower print that has the white plug with black and red wire.
there isnt much difference in 8 x aa(max 12V) and 3s lipo(max 12.4v), why would it matter with the DM regulator, its good up to way above 12V right ?
were you talking about the fuse ? the picture shows the location, could it be possible to use a 3a fuse there just like that, or even use a resettable fuse called 'polyswitch' or..? spektrum/jr have spare fuses, but probably not suited for a DX3.0
yep, you can have the pics, heres some more.
this show closeup of old regulator
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1500.jpg
this pic show the lower print and where to wire up a plug for battery connector
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1498.jpg
this show lower print on dx3.0, you can see there is no diode, but a wire connection instead
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/DSCN9282.jpg
overview pic of dx3.0 inside
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/DSCN9283.jpg
raw weight of a dx3.0 w/o batteries:
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1495.jpg
>For Spektrum DX7 users. Most all electronic circuits use some form of voltage regulator to take the various incoming voltage and regultate it to a constant voltage. I opened my DX7 and found the voltage regulator chip and it is labeld LM2937-3.3 Search for this part number on the internet you will find the data sheet for this chip. This voltage regulator is rated for a 26V input and has an output voltage of 3.3V So a 12.6V battery is not going to be a problem. People with other transmitters just need to find the voltage regulator chip and look up the data sheet to see if thier transmitter can handle the voltage. The voltage regulator is usually a 3 pin chip with a large metal heat sink. For surface mount boards it is usually one of the larger chips.
another interesting post:
>I have been using this battery in my Futaba 7C and 6EX transmitters for the last 6 months. I charge it to 12.6 volts (4.20 x 3). No problems whatsoever. Remember, some AA batteries can be as high as 1.6v. Do the math, 8 x 1.6v = 12.8v. This is .2v above the full charge of a 3S lipo. People are worrying for no reason.Travis 05/06/09
Can i put a 1s4p or 2s2p lipo pack inside the dx3.0 ? if the voltage regulator needs 3.3v only .. ? another post make me think it needs 5V internally:
>You will notice that many of the new 2.4GHz radios (Futaba 12/14 for example) now come with a 2-cell lithium battery (not a 3S).
This is because 2.4GHz systems need only 5V internally so a 2S lithium is perfect for the job. Unfortunately, a transmitter that expects a 9.6V NiMH/Nicad pack will beep low-voltage if you try to use a 2S Lipo ** however, in the case of the Turnigy 9X, the addition of a single resistor can fix that problem and allow a good-sized 2S LiPo to be fitted. That would give about a 30% longer run-time than when using a 3S lipo of the same physical size and also keep the internals (regulators) running much cooler.
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1497.jpg
Do you know if there is a way to fit in a fuse in dx3.0 ? there is a place for it, and i intend to use 3s 2200mah lipo pack in this transmitter.
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1503.jpg
http://www.cooperhandtools.com/brands/CF_Files/model_detail.cfm?upc=037103191311
Which is not only much quicker to heat up, but also has temperature controlled so that it is much better to work with. Bigger items get more heat, whereas smaller items get less heat.
I am also experimenting with 'preheating' items with a hairdryer so that they solder quicker with less thermal shock.
