3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Double the battery life of the DX3 Radio from Spektrum for under $20
Step 5Removing the Linear Regulator from the PCB.
  • C:\Documents and Settings\E039758\Desktop\Spektrum DX3 015.jpg
  • C:\Documents and Settings\E039758\Desktop\Spektrum DX3 016.jpg
This involves heating up the bigger end and melting the solder under it. It is a seperate step, because unless you de-solder the legs first, you'll never get the unit off the PCB.
The PCB is the heatsink for this part. And, I did some tests with my temperature probe--this sucker got HOT. All that wasted energy as heat means your batteries are going bye-bye. To remove the regulator, simply put your iron on the large flat metal piece and feed some solder into it. Push up against the part and you'll likely send it flying across your workbench. Don't worry--you shant need it again. Let it keep the dust bunnies company with it's radiating warmth and lack of efficiency at high voltages. They'll appreciate the company.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Spokehedz
