3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Double the battery life of the DX3 Radio from Spektrum for under $20
Step 8Testing the Regulator
Put a little more solder on the legs of the new regulator, and make sure that all connections are good. I do this by putting my DMM into Diode/beep mode and I touch the leg of the component near the component, and then another component that the trace runs to. On some circuits, this is easier said than done--but it is super easy on this one.
The two capacitors on each side of the old regulator gets a nice big trace to it. Simple touch the one probe of your meter to the regulator, follow the trace to the cap and touch the probe there. If it beeps or shows Zero-Ohm then your golden.
Next we get to test the radio. Turn on your receiver (RX) and wait for it to go into failsafe (3 sec). Then take your radio (TX) and put in the battery pack. You'll have to hold it in, as the bottom won't fit anymore.
Don't bother with the antenna or screwing on the back--just leave it off for now. Hold in the battery pack in and turn on the radio. Look at the display. Does it show a normal voltage between 11v and 10v? If it does, turn the knob and pull back on the throttle. If stuff moves, then your golden. Turn off the radio and the receiver, and put the battery pack off to the side once again.
If it dosen't, make sure your battery pack is charged and that you have it put in the right way. If it still dosen't work, go back and test your connections again. If it STILL dosen't work, then remove the regulator, clean the pads and the regulator legs of solder (solder-sucker!) and put new solder on.
19 comments
May 26, 2009. 3:27 AMaero007 says:
(removed by author or community request)
Nov 11, 2010. 6:52 PMGunny68 says:
Could you please tell me the model number of regulator that you put in the DX3???.Thank You,.........
Nov 12, 2010. 9:09 AMGunny68 says:
Thank You Very much.......
May 26, 2009. 12:21 PMaero007 says:
Not all understood. the 3s lipo is 115 grams each ( not bad, half the weight of the 2600mah nimh i have), to be charged to, say, 4.0V per cell. 3s packs are common to use even on dx3. comments on several sites say it lasts for months, compared to nimh where i have to charge every time, and its a drag..
I plan to solder wires on the lower print at the opposite side of the lower print that has the white plug with black and red wire.
there isnt much difference in 8 x aa(max 12V) and 3s lipo(max 12.4v), why would it matter with the DM regulator, its good up to way above 12V right ?
were you talking about the fuse ? the picture shows the location, could it be possible to use a 3a fuse there just like that, or even use a resettable fuse called 'polyswitch' or..? spektrum/jr have spare fuses, but probably not suited for a DX3.0
yep, you can have the pics, heres some more.
this show closeup of old regulator
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1500.jpg
this pic show the lower print and where to wire up a plug for battery connector
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1498.jpg
this show lower print on dx3.0, you can see there is no diode, but a wire connection instead
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/DSCN9282.jpg
overview pic of dx3.0 inside
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/DSCN9283.jpg
raw weight of a dx3.0 w/o batteries:
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1495.jpg
May 27, 2009. 4:39 PMaero007 says:
they are 2200mah 3s, actually arrived with a 0.09V reading on one cell and other were really low as well.. oki. i did not ask 'how long will they last'. they cant possibly last shorter than the 700 or 2600mah i have already. Being that i also count in 'OFF' time, meaning not having to charge all the time. in place of the fuse is a little smd or something whatever it is its small..
May 29, 2009. 5:34 AMaero007 says:
that jumper/zero ohm fuse, may have some limit right ? if a lipo pack would burn it up, its hard to replace. i have bought some fuse clips and see what i can do there..would it make sense to place a .500mah or 1a fuse in place ?
May 26, 2009. 2:11 PMaero007 says:
spokedhez, i found this on the internet:
>For Spektrum DX7 users. Most all electronic circuits use some form of voltage regulator to take the various incoming voltage and regultate it to a constant voltage. I opened my DX7 and found the voltage regulator chip and it is labeld LM2937-3.3 Search for this part number on the internet you will find the data sheet for this chip. This voltage regulator is rated for a 26V input and has an output voltage of 3.3V So a 12.6V battery is not going to be a problem. People with other transmitters just need to find the voltage regulator chip and look up the data sheet to see if thier transmitter can handle the voltage. The voltage regulator is usually a 3 pin chip with a large metal heat sink. For surface mount boards it is usually one of the larger chips.
another interesting post:
>I have been using this battery in my Futaba 7C and 6EX transmitters for the last 6 months. I charge it to 12.6 volts (4.20 x 3). No problems whatsoever. Remember, some AA batteries can be as high as 1.6v. Do the math, 8 x 1.6v = 12.8v. This is .2v above the full charge of a 3S lipo. People are worrying for no reason.Travis 05/06/09
Can i put a 1s4p or 2s2p lipo pack inside the dx3.0 ? if the voltage regulator needs 3.3v only .. ? another post make me think it needs 5V internally:
>You will notice that many of the new 2.4GHz radios (Futaba 12/14 for example) now come with a 2-cell lithium battery (not a 3S).
This is because 2.4GHz systems need only 5V internally so a 2S lithium is perfect for the job. Unfortunately, a transmitter that expects a 9.6V NiMH/Nicad pack will beep low-voltage if you try to use a 2S Lipo ** however, in the case of the Turnigy 9X, the addition of a single resistor can fix that problem and allow a good-sized 2S LiPo to be fitted. That would give about a 30% longer run-time than when using a 3S lipo of the same physical size and also keep the internals (regulators) running much cooler.
May 26, 2009. 8:41 AMaero007 says:
My DX3.0 has that regulator sitting far from the bind button, and i think the new regulator will fit fine in. thank you for helping. the instrutable was great as is, but you make it greater by well explaining things. Makes me wonder why there are no other comments.
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1497.jpg
Do you know if there is a way to fit in a fuse in dx3.0 ? there is a place for it, and i intend to use 3s 2200mah lipo pack in this transmitter.
http://i204.photobucket.com/albums/bb51/aero007/RCstuff/esav/mods/spektrum/DSCN1503.jpg
May 26, 2009. 5:02 AMaero007 says:
i might have used to LITTLE heat, or not get enough bond/solder legs w/ led tin, might have pulle a palte off the pcb with the pliars. worst case scenario..the iron was set to 300 celsius and i changed to a pin type soldering iron tip ok then i think i must solder wires onto those yellow caps, and the middle leg i can solder to the big flat ground plate right ? how much heat (celsius) do i need for the iron to be set ? i do not want to ruin those small caps, and a spektrum transmitter cost 300 dollars here, its terrible if this wont work..
May 25, 2009. 7:16 PMaero007 says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Spokehedz
