Step 9Putting it all back together
It's kinda tricky, but not too bad. The trick is getting it right over the connector. Put your pinky, or whatever you can under the floating PCB in the TX. Push down on the connector (gently!) and it will click/snap into place. Honest, it's a feather-touch here.
The connector will spin without popping off when it is on properly. Just don't go spinning it around in a circle like a goober. Once the antenna is back on, put the clear plastic bind button onto the LED that's sticking out of the black button, and put the case back on. If you angled your regulator correctly, you should be able to put the case back on and screw in the screws easily. If not... well... Go back and put it on correctly.
Don't go bending it like a hosehead either. You'll rip off the pads and then you will be up a certain creek without a paddle. so just don't do it. Re-soldering takes a minute, and it's easy.
Add Comment
