Introduction: Double to Simple to Double Again
I made it at Techshop
That is "Teeth Brutalis" our table saw at Techshop
She love bite acrylic, plastic and wood
Step 1: Let's Turn Off the Machine
Step 2: Remove the Key
Step 3: Remove the Screw
Step 4: And Take Out..
Step 5: Gorilla Tork to Release the Screw
Step 6: Remove Washer and Nut
Step 7: Remove Double Saw
Step 8: Press the Lock
Step 9: And Open the Side Door
Step 10: Lift the Locker Arm
Step 11: And Release the Saw Stop Key
Step 12: Remove the Saw Stop
Step 13: Take the New Saw
Step 14: Place in the Axel
Step 15: Washer and Nut
Step 16: Gorilla Tork
Step 17: Lift the Lock Arm
Step 18: Open the Side Door
Step 19: Get the Stop Saw Device
Step 20: May Be Clean the Place First
Step 21: Place Stop Saw Device in the Suport
Step 22: Lock the Key
Step 23: Lock the Arm
Step 24: Put the Plate and Lock It
Step 25: Close the Side Door
Step 26: And Lock It
Step 27: Very Well
Step 28: Than the Saw Is Ready to Use :)
Step 29:
Step 30: But May Be Now You Want Return to Double Blade Again...
Than simply go backward in this Instructable
or
... keep moving forward
Step 31: Turn Off the Machine and Remove the Key
Step 32: Lift the Locker
Step 33: And Remove the Guard
Step 34: Gorilla Tork
Step 35: Remove Washer and Nut
Step 36: Remove the Saw
Step 37: Get the Double Saw
Step 38: Put in the Axel
Step 39: Washer and Nut
Step 40: Gorilla Tork Again
Step 41: Unlock the Side Door
Step 42: And Open the Side Door
Step 43: Remove the Saw Stop
ATTENTION:
Only when you go from small to big size saw you can remove the Stop Saw AFTER change the saw, otherwise
When you go to small to big diameter saw YOU NEED REMOVE THE STOP SAW FIRST
If you try to do in the wrong way
You will figure out immediately because "Two bodies can not occupy the same position in the space in the same time"
Step 44: Take SawStop From the Box
Step 45: Place in the Support
Step 46: Tie the Key
Step 47: SawStop Done :)
Step 48: Close and Lock the Side Door
Step 49: Put the Plate
Step 50: And Screw It
Step 51: Put the Key and Turn on the Machine
Step 52: And You Are Ready to Go Make Cuts or Engrave? With Large Width
:) I made it at Techshop
