Downhill Ski ORIF
Introduction: Downhill Ski ORIF
This is a guide to fixing a broken pair of downhill skis
Step 1: Break Your Skis
I noticed a piece of my edge broke free from my skis after my most recent yard sale. Initially only a small bit was loose. I went down to the bottom and the edge was getting worse. I switched the foot the ski was on so the spur was on my outside edge and basically rode the inside edge of the downhill boot.
Step 2: Assess Damage
While exploring the extent of the damage, the spur of rail broke free from the side.
Step 3: Get Materials
I searched for edge material and didn't have much luck. I found The Holy Grail of Ski Building Info and wallowed my eyes on their shop for a few days. I was referred to Tognar and got a decent deal on a small piece of repair edge. Googleing snowboard and ski building supplies will get you other dealers but one wanted close to 20 dollars just to ship a 5 dollar piece of steel. The one I ended up getting had a deeper backing insert and was coated in a black paint to keep it from rusting.
Step 4: Operative Planning
Step 5: Chop
Step 6: Trim Your Edges
I trimmed the edges to get a good matching surface. The socket was chiseled clean to get a good interface for epoxy. The edges were left longer than the socket because I originally intended to solder it in. That didn't work out.
Step 7: Cut Your Patch
Cut it longer than the gap. You want this tight.
Step 8: Epoxy Everything
I used a fine bit and drilled pilots in the ski core along the replacement rail. The fine screw pictured is from the same place I got the rail.
Step 9: Grind It Out
The video I found showed grinding off the screw heads to prevent them from sticking through your PTEX. I didn't like the idea of cutting the screw heads off after gluing but it proved necessary. Realistically I will never have to take them out so I cut off enough to keep them below the base but left enough to keep the replacement rail trapped.
Step 10: Melt Some Plastic
I tried a variety of ways. One source said to blow torch it. I one saw a wizard make a bow out of PVC pipe with a blowtorch so I gave it a try. I could not keep it hot enough to repair a defect of my size. I also set it on fire a lot. The sticks of PTEX are called candles I believe, and typically you light them and they drip molten plastic into small gouges on your base. I settled on the oven because it would let me melt a whole stick. I melted it on parchment paper at about 450f/230c. If you don't bake, this is not wax paper.
Step 11: Press Base Material Into Defect
Step 12: Clean It Up
Step 13: The Clamps
Coat everything in epoxy again. I had to take the binding off to get it right. Just enough to squish it but not enough to pervert it's camber.
Step 14: Remove Excess Everything.
Your rail will probably stick out and require grinding.
Step 15: The Final Cut
I used a kitchen santoku to plane the base more or less flush.
Step 16: Sand It
I used coarse sandpaper. They make coarse files that supposedly do this very well.
Step 17: Ride It!
Get back on the slopes. Someone once told me repair is the highest form of recycling.
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
