Dr. Greene's Double Brew
618
Posted in FoodCoffee
Introduction: Dr. Greene's Double Brew
Would you like to make strong coffee at home using a drip coffee maker? Yes? Then I have the recipe for you. This coffee is so strong you'll be able to stand a spoon in your cup!
Step 1: Ingredients
Electric Drip Coffee Maker
At least 24 tablespoons of Coffee Grinds (You choice of coffee brand)
Tablespoon size scooper
Coffee filters
Filter Water or Tap water
Optional: Flavored Creamer
Step 2: Place Filter Paper in Coffee Maker
Open Coffee Lid, swing drip spout from over filter to position indicated in picture, and place filter paper in filter.
Step 3: Fill Filter With Grinds
Using the scoop, fill the filter with the desired amount of coffee grinds and swing the drip spout over grinds. NOTE: It is recommended to use one tablespoon of coffee grinds for each cup of coffee you want to make. To make 12 cups use 12 tablespoons of grinds.
Step 4: Fill Water Resevoir
Using the pot to measure the amount of water added, fill the pot to the desired cup mark, then then pour the water in the reservoir.
NOTE: the amount of water added depends on step 3. Use one cup of water for each tablespoon of grinds. If you use 12 scoops of coffee grinds, like me, use 12 cups of water
Step 5: Preparing the Pot to Brew
Close the lid and plug the machine into an outlet.
Step 6: Start the Brew
Press the start button. The start button may be located in a different location depending on the model of your machine.
Step 7: Wait for Coffee to Brew
Once the drip has stopped and the pot is full of coffee turn off the machine. This will tale 20 to 30 mins.
Step 8: Remove Old Grinds
Remove the old filter and grinds.
Step 9: Place Filter Paper
Place new filter paper in the coffee pot
Step 10: Fill the Filter With Coffee Grinds
Repeat step three.
Step 11: Fill the Reservoir With Coffee.
Pour all the coffee from the pot into the reservoir and close the lid.
Step 12: Start the Brew
Step 13: Final Product
Once the drip has stopped and the coffee pot is full the coffee is ready to drink.
    • Science of Cooking
      Science of Cooking
    • Space Challenge
      Space Challenge
    • Spotless Contest
      Spotless Contest
