Draft Detectors
5,050
47
7
Posted
Introduction: Draft Detectors
Chilly money sapping drafts are a pain - these simple units help to pin point areas of concern
Step 1: Materials -
Not much - A sheet of A4 printer paper - 3+ Pins - a small Pedestal - Blue Tak - Scissors
Step 2: Step 1
Assuming we are going to make three units - take your A4 paper and mark down 4inches from the top, cut a strip and fold it in half - repeat until you have three 2 inch strips, this is your basic structure
Step 3: Step 2
Take a folded strip and with the crease at the top mark a line one inch from the edge - carry that up towards the crease until you are 10mm away, put in a curve to follow for cutting.
Mark down 10mm from the spine and carry that along until your two lines intersect and using scissors cut out the L shaped profile
Step 4: Step 3
Take one of the short fat legs and fold it upwards - note the position of the fold - about half inch/12mm from the crease - you now have two parts that make up the rear vane, one (the lower) longer than the other
Step 5: Step 4
Take the end of the long shaft and spread it open to a distance of about two inches to make a horizontal paddle shape (I rounded the end for aesthetics) - this is your rising/falling vane
Step 6: Step 5
Take a pin, a small base or a big blob of blue tak and fix the pin into/onto it - the pin needs to be high enough so that the complete unit can move freely around in a circle and to some extent up/down - - - - repeat all stages until you have three or more units complete
Step 7: Step 7
Place the multiple units around a suspect area to confirm a source of a draft or like me ( unsure of the exact problem points - turned out to be multiple ) use the units to map out a room - larger diagram, red circles indicating problem areas.
Map out a room and address the issues - you will be surprised how long it takes once ya get going.
Step 8:
  • Homemade Gifts Contest 2017
  • Remote Control Contest 2017
  • Design For Kids Challenge
Questions & Answers
7 Comments
Cheers - thanks for posting
Darn. Good idea.
Hey, cool idea. I saw an artist do something like this for a wall mounted series, and the air currents made really great waves from the indicators! Thanks for sharing.
Hi - cheers for the comment, if you had the name of the artist I would like to see some of their work - love art with life and movement.
Found him! Charles Sowers-
See a page about his work: http://laughingsquid.com/windswept-a-wind-powered-kinetic-sculpture-by-charles-sowers/
And bene for me - it's in SF!
Checked his work out - the guy is amazing - thank you so much for mentioning him - will scout around for more pieces and displays.
