DragonBoard 410c and LED Strip 5050 (Beginners)
Published
Introduction: DragonBoard 410c and LED Strip 5050 (Beginners)
When I started working on a DragonBoard 410c, I had so many difficulties to find simple things tutorials, because the makers assume that you already know how to do the basics, then in this tutorial, I will explain in detail how to connect and use a LED strip RGB 5050 with the DragonBoard 410c (DB 410c). This method you can use for others things like DC motors, etc.
Step 1: Materials
1 - Keyboard;
1 - Mouse;
1 - Monitor with HDM;
1 - Protoboard;
1 - LED Strip RGB 5050;
3 - Tip 122;
Some jumpers.
Step 2: Install Debian
Follow this tutorial to install the Debian System: 96 Boards Tutorial
Step 3: Step 3: Start the DragonBoard 410c
Connect a monitor, keyboard, and mouse. It can be used as a normal Linux desktop computer if you attach a keyboard, mouse, and monitor. Use the “Terminal” application to get a command prompt.
Step 4: Connect to the Internet
On the bottom right side, has an option to connect the DB 410c to the internet, like a Linux.
Step 5: Update Debian
Make sure all of the Debian packages are up to date before trying to install the packages.
Put on LXTerminal:
sudo apt-get update
sudo apt-get dist-upgrade -u
Do you want to continue? [Y/n] y
Step 6: Install Extra Tool Packages
To run these demos, we’ll install the Debian packages for the standard Linux development tools, the Python environment, and the Arduino toolchain. Then we'll install the MRAA and UPM packages from source.
Put on LXTerminal:
sudo apt-get install arduino-mk arduino git build-essential autoconf libtool swig3.0 python-dev nodejs-dev cmake pkg-config libpcre3-dev
sudo apt-get clean
Step 7: Configure the Software
The last step is to install some configuration files so that the development tools know which devices to use. Fetch the 96boards-tools package and install the provided configuration files:
Put on LXTerminal:
sudo adduser linaro i2c # Allow the normal user to perform i2c operations
git clone https://github.com/96boards/96boards-tools
sudo cp 96boards-tools/70-96boards-common.rules /etc/udev/rules.d/
cat | sudo tee /etc/profile.d/96boards-sensors.sh << EOF
export JAVA_TOOL_OPTIONS="-Dgnu.io.rxtx.SerialPorts=/dev/tty96B0"
export MONITOR_PORT=/dev/tty96B0
export PYTHONPATH="$PYTHONPATH:/usr/local/lib/python2.7/site-packages"
EOF
sudo cp /etc/profile.d/96boards-sensors.sh /etc/X11/Xsession.d/96boardssensor
Now reboot the system to pick up all the changes:
Put on LXTerminal:
sudo reboot
Step 8: Fetch the Sample Code for Projects in This Guide
Put on LXTerminal:
git clone <a href="https://github.com/96boards/Sensor_Mezzanine_Getting_Started"> https://github.com/96boards/Sensor_Mezzanine_Gett...</a>
Now, on Downloads folder, you have so many examples files to help you on future projects.
Now, let's start to get the hands dirty
Step 9: The Hardware
The LED Strip work with 12v, and the Dragonboard with 1.8v. But, the strip works with a common positive, and individual GND for triggering the colors. The Tip 122 work triggering GNDs with the 1.8v from DB 410c.
The only thing you need to do is connect the common positive from LED Strip to the 12v(positive of the DC Power), and the negative from the DC power to the emitter of Tip 122. To turn on the LEDs, connect the individual GNDs to the Tip 122 collector. The base, you connect to DragonBoard GPIO pins. Follow the image attached.
(Attached image with DragonBoard and Tip 122 pin out)
Step 10: The Software
On the DragonBoard open the folder would you like to save your project and with the right button click on a blank space, and select "New File", put the name of the project and the extension ".py" like this: "ledStrip.py"
Open the file and paste the attached code that was taken from one of the examples in the UPM library. (This case I use pins 27, 29 and 31 on DB 410c)
Step 11: Execution
Now, after saving the code, you should open the LXTerminal (On system tools) and the two commands with you most use: "ls" to list all items in the folder, and "cd" to get in a folder, and you should go to the folder you saved the code file to.
Ex: If my code file (ledStrip.py) are in a "Codes" folder on Downloads, I type this on LXTerminal:
cd Downloads
cd Codes
Now, when I'm in the folder, I open the code file with the command:
sudo python ledStrip.py
And the code is executed. If have an error, it will show on the LXTerminal
Step 12: References
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
