Introduction: DragonBoard: How to Access GPIOs and Analog Pins
Sample to show how to access and use the GPIOs and Analog pins
Step 1: Install Dependencies
To access the pins from the dragonboard, we're going to use the MRAA library to keep this really easy, but to use this, we need to setup a fill things before start.
MRAA library needs to setup some environment variables on the DragonBoard.
NODE_PATH="/usr/local/lib/node_modules" PYTHONPATH="/usr/local/lib/python2.7/site-packages" JAVA_HOME="/usr/lib/jvm/default-java" export NODE_PATH export PYTHONPATH export JAVA_HOME
Install NodeJs:
- apt-get install git gcc g++ python2.7 build-essential
- cd ~/Documents
- git clone git@github:nodejs/node.git
- cd node
- ./configure
- make
- sudo make install
Step 2: Install MRAA Dependency
After setup the environment variables we need to install the direct MRAA dependency. This library needs SWIG with minimum version 3.0.5 and to install it, you just need to follow this steps:
- git clone https://github.com/swig/swig.git
- cd swig
- ./autogen.sh (it creates the configure script)
- ./configure
- make
- sudo make install
Step 3: Install MRAA Library
To install the MRAA we have two options to do it, first and the easiest way is install using npm:
- npm install mraa -g
and the other way is building the source code from Github
- git clone https://github.com/intel-iot-devkit/mraa.git
- cd mraa
- mkdir build
- cd build
- cmake ..
- cmake -DBUILDSWIGJAVA=ON ..
- make
- sudo make install
Step 4: Access GPIOs and Analog Pins
Now, after we install all dependencies that we need, we're able to access the pins.
for example, we're going to write 0 or 1 in some GPIO.
Here I have a simple led connected on port 27 in my DragonBoard:
var m = require('mraa'); var myDigitalPin = new m.Gpio(27); //setup acess to pin 27 from dragonboard myDigitalPin.dir(m.DIR_OUT); myDigitalPin.write(1); // 1 to enable and 0 to disable
In this sample, I'm using the MRAA to be able access the GPIOs without any problem.
I'm setting my variable to connect into the pin 27 using "new m.Gpio(27)", then I need to set the direction from my variable, in this case I'm using this variable just to write in this port. After set the variable to write, we just need to set the pin with zero or one.
And to read values from analog pins, we can use the follow sample:
var mraa = require('mraa'); //require mraa console.log('MRAA Version: ' + mraa.getVersion()); //write the mraa version to the console var analogPin0 = new mraa.Aio(0); //setup access analog input Analog pin #0 (A0) var analogValue = analogPin0.read(); //read the value of the analog pin console.log(analogValue); //write the value of the analog pin to the console
