loading
Step 2: Laser Cutting
The drawings were cut at FedTech. Thank you FedTech! There is not much to say about this step except that I had to punch out the little hexagons that were a little stuck in the wings (they had been cut but didnt fall out).
<p>That metal folded dragonfly is so cool. Did you make it yourself or get the design from somewhere? How difficult was it to make? How big is it when completed?</p><p>Elisa Jed | <a href="http://www.shoreviewmetalcraft.com/part-services.html" rel="nofollow">http://www.shoreviewmetalcraft.com/part-services.h...</a></p>
I designed it from pen first and then drew it up using simple CAD software. I made it while in a class that had a field trip where I was then able to get the design laser cut. There were many designs leading up to this and still many errors in the final design but due to constraints and only a couple days to draft the whole thing I am very happy with the result! :)<br><br>It was not difficult to make but has the caveat that you need access to a laser cutter or water jet cutter to cut the sheet metal. <br><br>Without the model in front of me I think it is around 8-9&quot; long. You could probably figure out the exact size by opening up the file.<br><br>The link you posted is right next to my home :) Can't picture where it is though exactly.
I said that time travel is controlled by the time cops now hundred percent its only fresh breathable air suplly the feeling of walking outside and odorelss the only chemical added is anti demon power. The time cops said there will be no wink them out of existance weopons on the world no phase them out of existance tech is allowed all papers and computer files on that burnt up any one or any device used to pass nuckles through ones skull is burnt up or sended to space station 30,000 light years away as long as the planet exist. Time cops of the world gov said there will be no time travel allowed in biuldings or any where where theres a door way you can only turn on magical science of interdemensional time warp tech on the road less travelled. <br> <br>You can email or fax the time cops that set this in stone for all time on all worlds wherever theres movement in space also. They said you can fax 8 idias on miracles made with time travel from the future probably 4 things to fix the world at large and 4 things to ask for seriose help for your own town or household this is a mild request the time cops control it not you. And they will stay 4 blocks city sections away from your house most likely wont use your ideas at all, fax it in any way they care about what you think about using a real time machine <br>
that would look great hanging in a tree ! you're right, the wings turned out awesome
About This Instructable
4,852views
19favorites
License:
More by Onyx Ibex:3D Printed Heng Lamp Lucina / Chrom Sword (3D Printed) Illuminated Rocker Switch Voltage Conversion
Add instructable to:
