Step 4Install the trucks
Once you are certain of your measurements and truck placements, it is time to do the marking of the drill locations. Use a pencil to mark in each truck hole, and remove the truck. Do this for each truck.
Use your drill to slowly drill through each whole. When finished with each truck, insert each bolt (from the bottom (or top of the board) so that the nuts are placed on the truck-side of the board. Once each bolt is on, ensure that the truck fits properly. Now move to the next truck and repeat.
Once all trucks holes are drilled, add truck, bolts, washers and lock nuts and tighten.
Add Comment
