3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drainage Luge
Step 7Other designs?
Other designs?
There are most certainly other designs for a drainage luge board. The purpose of this instructable is to show you how to create one variety of these boards. You will find, as I have, that there are numerous other designs you can create.
Design #2: Imagine a board with a 'V' under the board with trucks riding along it, so eight wheels are always touching.
Design #3: Imagine a board with larger wheels that are spring loaded and steer automatically.
There are always interesting designs, which is why the drainage luge is a sport that has numerous possibilities.
3 comments
Sep 7, 2011. 2:47 AMKelticpaddler says:
Mate, I love your sense of adventure. Good 'Ible. :O)
I wish we had similar drainage ditches where I live.
Aug 5, 2008. 2:32 PMHorny Toad says:
Awesome instructable! How long did it take you to make the board? What was your top speed flying down that hill?!
Aug 5, 2008. 6:04 PMRishnai says:
How do you plan on braking it? The alpine slides around here are pretty torn up from steel brakes rubbing against them, and while that is okay for an alpine slide, putting big scrapes all over the city's drainages might be a little unpopular. I personally would use chunks of large-diameter PVC pipe (since the large radius means sections will be nearly flat, having maximum contact patch), which will be forced down against the pavement using a lever system. I've used a very similar method to brake my downhill kart for years. It can stop a person on a kart going 30mph in about the same distance as car could stop.
Aug 7, 2008. 12:37 PMstimps says:
Yeah, the alpine slides that popped up all over BC in the 70s were all shut down by the mid-to-late seventies because they hadn't really thought of how different a child or an adult were in terms of shooting them down the side of a mountain. A plethora of a) massive injuries b) massive lawsuits sprung up, and alas, no one has thought to try it again. I'd suggest if you really want to get interested in it, find out some deep knowledge about it from years past.
Aug 7, 2008. 11:27 PMRishnai says:
We've got a few commercial alpine slides in the foothills around here, and you can get going at a pretty good rip. What they've done, though, is banked the turns a lot, so it's really tough to spill it. I did it once (they wondered why I was going up the lift with a motorcycle helmet...) and it took huge effort, and what tossed me was hitting an expansion joint and flipping forward/sideways. Hurt, but then I knew just how far I could push it before bad things happened.
Aug 8, 2008. 3:33 AMstimps says:
Aha! That makes sense. I wish they'd have done something like that around here instead of shut them down.
Aug 7, 2008. 2:22 PMstimps says:
It actually is true, in at least 2 provinces that I know of. It's just not true where you are. =)
Aug 7, 2008. 11:16 AMmrmath says:
I'd use a breaking system that applied friction directly to a set of wheels. For example, lever against both back wheels at the same time. Friction there won't cause damage to the drainage ditch, and it won't leave PVC filings behind.
Aug 7, 2008. 11:47 PMRishnai says:
Good idea, but when pointing it downhill, the caliper brakes from a bicycle won't hold a mountainboard in place. Not enough leverage, since the wheels are too small. I can see the allure in not leaving a sreak of white all down the road or ditch anymore. I'll have to look into braking systems.
Aug 8, 2008. 3:26 AMmrmath says:
No, I meant something like a length of copper pipe used as a lever against one of the wheels.
Aug 8, 2008. 10:27 PMRishnai says:
Might work. I'm still worried about the clamping force, but it sounds reasonable enough to build a simple prototype of.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:pbshoe
