Introduction: Drakan - Arokh Statue
"Who has awakened me?!" Probably the most iconic quote in the game Drakan, spoken by Arokh when Rynn awakens him with his soul crystal.
I managed to get the Drakan editor working and was able to export static objects like this one! You will need Pepakura in order to open the files. Just print, cut and glue him together. You can scale him as big as you want using Pepakura Designer. If you are interrested in Drakan, be sure to check out Arokh's Lair!
>>> Download Drakan_ArokhInStone_Papercraft here<<<
Download Pepakura Designer here: http://www.tamasoft.co.jp/pepakura-en/
You can see the statue at 18:14 in the video below:
Step 1: Materials
Material list:
- Aleene's Tacky Glue (can be found at Pipoos)
- Cutting knife/scissors or Silhouette Cameo 2 (cutting machine)
- Cutting mat
- Black marker
- Tweezers (recommended)
- Paper
- Printer
Step 2: Print, Cut and Glue
- Print out the templates.
- Cut out the parts and use a black marker to hide white edges of the paper. Only use it at dark parts!
- Fold and glue the parts together.You should start with the most tiny/detailed part and that is the head. Work your way towards the tail and wings. Glue it flap by flap and ring by ring. You can also cut out and directly glue one part at a time so you don't accidentally lose a (tiny) part! You can fold using a ruler, a scissor or slightly go over it with your cutting knife.
__ _ __ = valley fold
__ __ __ = mountain fold
If you have a Silhouette Cameo, you can use that to cut the templates by making use of the Cameo plugin for Pepakura. Found here: http://www.tamasoft.co.jp/pepakura-en/download/vi...
If you need some more help here are some useful papercraft tutorials:
