The controller has a tiny spring hooked onto the throttle that keeps it down. To remove the spring, remove the screws on the back of the controller. There is one behind the charging cable, just pull the slider back, then pull it off at a slight angle. It might take some force but be real careful! After that, flip the controller over and pull the front part off. Remove the screw holding the spring in place and pull the spring out. Screw the screw back in. Take the spring and hook the two ends together, forming a circle. Then take the circle on with the hooks facing down, so that the spring rubs against the throttle, forming a little bit of friction. Then take the charging cord and untie the knot, giving you about an inch extra of cord. Then put the front panel back, flip it over, put the screws back and pop the slider back on.
Without the knot when you pull on the cable you pull directly on solder points.
If you have no soldering skills this will not be a pleasant experience.
- Building King
Always when modding stuff is good to think in the future, any mod that is intended to be permanent must be thought trough in terms of reliability.
Also, in you case, after undoing the knot, if available, a small drop of hot glue would make it safer to use and you could benefit froom the ease of mind.
Today I looked at a ~100 USD, 4ch, helicopter in a hobby shop that I trust and it;s the next thing I'm buying :))
second, i have this specific heli and it works very well stock. this is no heli that needs to modded, and really, if it doesnt come with aftermarket upgrades, it means that it shouldnt be modded. the only thing here that is of any use to people is removing the spring from the throttle, which i did months ago because it makes it harder to fly.
one more point, if you mod something, try to make it possible to un-mod it. like the spring on the throttle, it can be put back. cutting the wires on the led is stupid. unsolder them or something so you can add it back later.
-Building King
