3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Draw Electronic Schematics with CadSoft EAGLE
There are a couple instructables here on some of the finer points of Eagle (making your
own library parts: http://www.instructables.com/id/ERHQQ180Y3EP286NQY/
modifying the design rules: http://www.instructables.com/id/EZVIGHUBGCEP287BJB/ )
But feedback indicates that a lot of people could probably use an instructable on the
more basic aspects of creating a schematic and board.
This instructable covers creating a schematic, presumably from a printed schematic in
a magazine or image on the web. I'll start with schematic shown, which is from
http://www.bowdenshobbycircuits.info/555light.gif
It's got a "typical" collection of parts, and is vaguely useful as well.
Cadsoft EAGLE generic information:
Cadsoft EAGLE is available from http://www.cadsoftusa.com/
Cadsoft is a German company that is a veritable mecca of software distribution enlightenment. In addition to the reasonably-priced professional PCB design packages ($1200), they have freeware, lite, non-profit, and other intermediate licenses. Their software runs under windows, linux, and MacOSX. It's slightly quirky, with a steep (but not too high) learning curve on the front end, but from most reports it is not any more so than other professional CAD packages. They have online support forums that are active from both the company and other users, the package is under current development and gets better with each release. A number of PCB fabricators will accept their CAD files directly. It's good stuff.
Use it. Propagate it. Buy it when you "go pro."
See also:
Creating PCB from Schematic
Creating Library parts
Design rule modification
Send CAD Files to manufacturers
Step 1Create new project
Start up the Eagle control panel, and right-click on "projects" to create a new project.
You'll get to name it whatever you want.
119 comments
1-40 of 119next »
Apr 9, 2012. 12:45 PMdonfrench says:
Thanks a lot for the resistor coding info. I did a lot of unproductive searching before I found this page.
Feb 29, 2012. 1:47 PMomnibot says:
"You might think that you'd use the "wire" command to make connections in your circuit."
-Why yes, that's exactly what I thought and apparently why it's NEVER worked before for 2 years of trying. You'd think they'd something like that on the first page in the manual. I am so angry right now.
Feb 8, 2012. 9:54 PMdav3id says:
Thanks, Had used Eagle several years ago but this really helped quickly figure out a couple of things that could have taken a lot longer before I got going, it was a great starting point / refresher for this new project.
Feb 3, 2012. 5:15 PMSharpyWarpy says:
Okay I clicked on the "Display" button and made visible only Bottom, Pads, Vias, Holes and centerDrill layers. Clicked "Tools > Ratsnest" to bring up the ground plane. I clicked on File > Print. Then in the dialog box part "Printer:" I chose "Print to File (Postscript)" and also in the "Options" I checked the "Black" box. I changed the "Paper" option to "Letter", which might not have really been necessary. I made sure "Scale" was set to one and then changed the save directory to my home directory and clicked "OK". I opened a postscript viewer -- in my case "Evince" and opened the file and printed. The drill holes were there. I'm happy.
Feb 2, 2012. 4:52 PMSharpyWarpy says:
I have a problem when I create a board from the schematic. I move all the parts relative to the schematic as directed in this tutorial but when I generate the board the wires go right into the holes! And I can't get them to back up. So when I etch the board I'm not going to have holes in the copper where they need to be. The only thing I can do is delete the wires one at a time and draw them each by hand stopping the ends just short of the holes in the pads or vias. But then after that I lose the annotation between schematic and board. Is there a design rule I can use to fix this? I made my own design rule configuration file but I didn't see anything in there about this problem. What can I do? Thank you all ahead of time.
Feb 3, 2012. 4:35 PMSharpyWarpy says:
Thank you, westfw for your reply. After I posted I did a bit more searching and discovered the "drill-aid.ulp", tried that and thought it was not working because it doesn't show up but if I understand you correctly it will show up on the printout? So should I save the layout in monochrome and postscript format for printing?
Jan 23, 2012. 5:02 PMSharpyWarpy says:
Interesting you used one of Bill Bowden's circuits. He's one of my favourites from which to learn. He's very approachable and very nice. I've built 6 or 7 of his circuits and they always work fine. Great Instructable, I appreciate the time and effort you put into ALL your Instructables. Your effort is not wasted.
Nov 20, 2011. 3:21 PMmspinks says:
I can't believe I was using the wire command this whole time! This is so much faster! Thank you!
Jul 31, 2011. 6:36 PMFieldingBlue says:
Thank you for all your effort putting this instructable together. I had been complete lost as to how to drive eagle until I read your excellent work.
Jul 6, 2011. 3:50 AMRue Dee says:
Never-mind, i have just realized the mistake i was making..
Jul 6, 2011. 3:42 AMRue Dee says:
Thanx for the drop button issue, i did the same.. i'm trying to add a 6 pin molex connector. But when i select it and click ok nothing happens, what should i do?
Jul 5, 2011. 11:47 PMspsj21 says:
it is really a nice instructable. So far I was struggling for a nice EAGLE tutorial and finally it helped me a lot.
May 17, 2011. 6:07 PMtcarney57 says:
I'm just now giving Eagle a try. Thanks for the introduction. Already I'm not surprised this is a foreign (German) program--I think some of the words and labels are poorly translated. Like Stainsor, I would have assumed drop meant to place the part on the schematic. It seems to me that "remove" or "delete" would have been better. But to use "drop," as in "drop like a hot potato," or "drop the course" doesn't work in this context.
Likewise, why is the word "smash" being used for a function that "[s]eparates text variables and attributes from parts or elements." And what does "separate" mean in this context? That the variable or attribute labels can be moved to a different spot around the part symbol as needed to make the drawing more readable. Wouldn't "rearrange labels" or even "detach" be better in the help-file description than "separates."
After I learn and grouse about these little quirks a while, I think Eagle will be very useful, especially since it seems to be a quasi-standard in the low-end (or free) market.
Mar 13, 2011. 7:33 PMbadbad214 says:
Thank you!
Feb 25, 2009. 5:14 AMstainsor says:
DO NOT click the "Drop" button in the Add dialog. My first time using Eagle I thought that was the button to drop a part into a schematic. It turns out that's the button to remove a set of parts from the libraries! If you do click this button and accidentally remove some of the libraries you can get them back by reinstalling Eagle.
If I knew anything about UI design (which I don't) then I would probably say that this was a horrible choice for both the placement and naming of the button. I would probably think that it should be changed immediately.
May 31, 2010. 11:52 AMwebster32 says:
It's very misleading, but all you've actually done is "disable" that particular library. The Control Panel window that opens on startup allows you to re-enable that library. Just expand the "Libraries" and click the dot beside the library you disabled.
Mar 13, 2011. 6:28 PMbadbad214 says:
Thank you webster32
Jan 28, 2011. 7:30 PMCobalt59 says:
Thank you. I did the same thing as Stainsor. :)
Jul 11, 2009. 2:29 PMtamentis says:
That's also what I initially thought, I tried it on a random weird component by curiosity.. It doesn't warn you, there is no tool-tip.
Mar 3, 2009. 10:32 AMrachel says:
Ha! I was just about to add this same comment, as I had the exact same wrong thought about what "DROP" meant. It's a terrible design choice and doesn't even have a confirmation dialog! Danger Will Robinson!
May 5, 2009. 4:27 PMjoie2vivre says:
Looks like you can get the library back by clicking on library/use, then select the library you want
Feb 14, 2010. 3:14 PMamando96 says:
 haha i pressed that aswell, but never figured out what it did xD
Feb 26, 2011. 7:04 PMRuss1234 says:
You have 2 diodes on Q2. Thanks for these tutorials.
Feb 1, 2011. 8:28 PMmauselous says:
Thank you so much for the helpful tutorial. The steps you illustrated really helped me get a handle on getting from circuit to schematic to layout.
Do you have any tips on where to find additional or alternate libraries that are more organized?
Jan 28, 2011. 7:50 PMCobalt59 says:
Where to find a + to GND power supply in the ADD dialog?
Jan 14, 2011. 11:09 AMmrmizuno1 says:
Thank you. very helpful.
Jan 13, 2011. 5:41 PMcoryjrogers says:
"your mouse pointer BECOMES your drawing tool"
Dec 2, 2010. 7:21 PMihart says:
Thanks for doing this. Now I need to check out your PCB instructable.
Oct 6, 2010. 8:31 PMklarkg says:
Does anyone know of a website that has a good picture library of parts with the eagle cad names? Im having problems finding basic stuff sometimes like headers I need and the names in the eagle cad library confuse me , this instructable helped me alot thanks!
Sep 28, 2010. 8:02 AMTaher81 says:
Do you have any schematic capture of an ADSL Modem?
Thanks for sharing with us.
Aug 17, 2010. 7:42 PMabraxas2 says:
Ok but how do we move a whole cluster of components. ? I tried group followed by move but no joy. By some miracle and a lot of attempts, I managed to combine two schematics and need to move one relative to the other. Thanks for this great tutorial, by the way. It is appreciated.
Aug 21, 2010. 2:45 PMadrenalynn says:
Did this get answered for you? In 5.x, you use the group (select box, rubber-band box, marching ants, what-have-you) to select the components, then select the move tool. Now - _look at the status line_ - it tells you that CNTRL + RIGHT-CLICK moves the group. Hope that helps!
Aug 17, 2010. 8:08 PMabraxas2 says:
OK I got it but damned if I remember how. I think I used the group command, highlighted the cluster of components and then right clicked on the selected cluster and saw a pop up saying move and right clicked again. I don't want to mess with it by doing it again. Maybe you can verify the steps ??
Jul 6, 2010. 5:31 PMpepegrillo says:
thank u very much! i can now draw pcb. THANK U!
Apr 12, 2010. 4:16 AMMarnick says:
Thanks for this tutorial, it helped me getting along this fantastic, but comprehensive program!
1-40 of 119next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
