3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Draw Electronic Schematics with CadSoft EAGLE
Step 14Neaten things up
Neaten things up
We can make things a bit neater by moving some of the components, junctions, and wires around just a BIT using the Move button. When you select an object after clicking the move button, the object gets attached to your mouse pointer and behaves like when you were adding objects with respect to the other mouse buttons.
3 comments
Aug 17, 2010. 7:42 PMabraxas2 says:
Ok but how do we move a whole cluster of components. ? I tried group followed by move but no joy. By some miracle and a lot of attempts, I managed to combine two schematics and need to move one relative to the other. Thanks for this great tutorial, by the way. It is appreciated.
Aug 21, 2010. 2:45 PMadrenalynn says:
Did this get answered for you? In 5.x, you use the group (select box, rubber-band box, marching ants, what-have-you) to select the components, then select the move tool. Now - _look at the status line_ - it tells you that CNTRL + RIGHT-CLICK moves the group. Hope that helps!
Aug 17, 2010. 8:08 PMabraxas2 says:
OK I got it but damned if I remember how. I think I used the group command, highlighted the cluster of components and then right clicked on the selected cluster and saw a pop up saying move and right clicked again. I don't want to mess with it by doing it again. Maybe you can verify the steps ??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
