Step 6Add capacitors
Polarized caps are similar (CPOL-US or CPOL-EU in rcl.lbr), with a package name like TSSS-DD, where
T is a type designator (E for electrolytics, TT for tantalum drops, for instance) SSS is the spacing again
(only now it probably has an actual decimal point!), and DD is the diameter (for radial caps)
Most hobby projects can get away with either 2.5mm or 5mm lead spacing, and the designer "remembering" to leave enough space for the physical capacitor body; there might not be a silkscreen anyway.
(the "silkscreen" is the pictures and text describing the components, usually printed in white ink on the component side of the board (if you had it made professionally.) Library designers spend a lot of time getting the silkscreen to look nice; all wasted if you make a board that doesn't have that printing.)
comment
Add Comment
Add Comment
