Draw Your Own Labyrinth.
CraftArt by
26,701
42
15
Posted
Introduction: Draw Your Own Labyrinth.
A labyrinth is not a maze. Mazes are puzzles, designed to vex the mind, but labyrinths are contemplative designs, designed to focus the mind.
It is an ancient design, found carved into churches, temples and tombs around the world.
They are also easy and fun to draw, once you have the key.
Step 1: The Key
The key is the simple pattern around which the labyrinth is constructed. Most are based on crosses, and it is the order in which the points are connected that creates the form of the paths.
Step 2: A Simple Key
The simplest key is a single cross plus four points (see the first image). If you join the points in the order they are numbered, you will produce the simplest unicursal ("single path") labyrinth - follow the path with your eye or finger, and you get to the centre. To get back, you re-trace your steps.
Step 3: The Common Key...
Most labyrinths start with a key like the one in the first image below. Following the numbered points also produces a simple unicursal labyrinth.
Step 4: ... Made Less Common.
Using the same keys, but re-ordering the points, produces more interesting labyrinths.
This is also unicursal, but with a twist. Try it to find out why (don't join a line to the point marked "X").
Step 5: Some Keys to Try.
The same basic key can be given more than one layer. Keys are also not restricted to simple crosses.
Try starting with the keys in the images below, experimenting with the ordering to see what happens to the path.
Step 6: Like Minds.
It turns out (thanks, Adam), that there are people dedicated to labyrinths as art, mathematics and mysticism.
Some of their ideas are a bit "new age" for my taste (the "Energy Keepers" need ti get a better grip on reality, I think), but there is still lots of useful stuff on their site:
http://labyrinthsociety.org/
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    15 Comments
    that's interesting, I used to draw impressive labyrinths on squared sheets when I was at secondary school. Some of them filled a full double A4 sheet and my deskmate took a lot of time to solve them :-)
    the most complex labyrinths had secret passages and keys to find to open doors! LOL
    which are are you?
    hoggle, ludo, or jereth (the goblin king played by David Bowie)?
    I drew a 7-layer 'rinth on time. It was epic.
    Thank you very much, Kiteman! I'm going to use this in an upcoming English project.
    sweet, mine turned out weird but cool
    Very Cool! I'll totally give this a try!
    this instructable is great i do it in school everyday i get in trouble but oh well : - )
    You may want to add a link to The Labyrinth Society so people have somewhere else to turn if this instructable piques their interest, as it did mine.
    For instance, the centralized design fungus amongus requested can be found on this page about classical concentric labyrinths .
    I'm hoping to build my own labyrinths and gardens, and this is a great starting instructable, thanks!
    -Adam
    Moving in southeast michigan? Buy my house: http://ubasics.com/house/
    Interested in electronics? Check out the projects at http://ubasics.com
    Building your own house? Check out http://ubasics.com/home/
