This instructable has been removed by the author.
12
comments
Add Comment
Mar 5, 2007. 5:48 PMmfacer
says:
this is a cool idea - I'm going to apply it to my cupboards tomorrow... I've got two magnetic contacts, around 15 white LEDs and a load of wire. As I'm fairly new to this game, what's the best way to power it, and how to hook together the LEDs. Is it just easier to but an LED strip light and plug it to the mains?? thanks for any advice!!
Aug 11, 2008. 5:52 PMhovis
says:
mfacer: Whenever I do a simple project like this my favorite power supply is an old "power brick" transformer. Most everyone has chargers from old cell phones, etc, lying around, I just cut off the "little" end, strip the wire, and solder in place. Make sure to match the right transformer to the right job though, you don't want to have to use too many resistors to drop the voltage.
Apr 23, 2006. 7:26 PMelmetal
says:
I would Grind the head of the LED so the light isn't directed it's more of a ambient light,
May 5, 2008. 5:23 AMrajarshi
says:
i have a bedside with a tinted glass top which can trasmit light. can there be a way that after i shut the drawer, the led is lit for a few seconds and then shut off?
Jan 16, 2008. 3:43 AMtong-b
says:
I made one with a cupboard that has a swinging door and made a switch out of a block of wood the I staple gunned some paper clips to and bent the clips in a way so that when the door closes it pushes the clips apart. not pretty but works and good for a quick job without much stuff
Aug 14, 2007. 7:35 PMrattha
says:
Cool you 're stay to protect,Durex man ---555 just kidding . This is very cool idea.
Nov 17, 2006. 11:37 PMandrestuff
says:
DollarTree $1 store is selling magnetic window alarms that have 4.5 volts
inside them with a reed switch. I'm pretty sure if you picked up off the end of
the reed switch you would get 4.5 volts. Then just a dropping resistor and don't forget to disable the alarm part of the unit. Here's the unit itself.
http://www.asseenontvguys.com/ProductImages/firstlarge.jpg
Use 3 x 1.5 AA batteries if you need more long lasting power and solder
wires from a battery holder to the pins inside where the A77 batteries are normally inside the alarm housing.
Mar 8, 2006. 6:41 PMrobacarp
says:
Great Idea! Before reading it I had pictured using a microswitch instead of a reed switch. I like the reed switch better....but I would have mounted it near to the front of the drawer instead of the back, that way if you need to silence the light you can just stick a magnet to the switch.
Apr 4, 2006. 5:52 PMbassler
says:
Here's the picture. Sorry it didn't attach with my first comment.
Apr 4, 2006. 5:50 PMbassler
says:
That's a clever solution! Here's a more convenient option...I found these at http://www.davidsteele.com
Mar 10, 2006. 11:14 AM007ben (author)
says:
I had 1st thought of using a microswitch as well but decided the reed would be easier to work with. I had considered that putting the reed swtich closer to the front. The construction of the night stand made it diffult to put the reed switch anywhere else. If I found a smaller one it may have been possible. I'm not often using the drawer for long periods. Also the book light LED used has a switch on the top of it as well if it really needs to be off.
