This instructable has been removed by the author.
12
comments
Add Comment
inside them with a reed switch. I'm pretty sure if you picked up off the end of
the reed switch you would get 4.5 volts. Then just a dropping resistor and don't forget to disable the alarm part of the unit. Here's the unit itself.
http://www.asseenontvguys.com/ProductImages/firstlarge.jpg
Use 3 x 1.5 AA batteries if you need more long lasting power and solder
wires from a battery holder to the pins inside where the A77 batteries are normally inside the alarm housing.
