3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drawing Machine
Drawing Machine
How I made my drawing machine, and in the process made artists obsolete. When I first moved into my new studio, I had no important projects looming, and wasn't yet comfortable in the space. I built this "Drawing Machine" so that I could be productive, but not really. I would set it up, turn it on and then read Sculpture Magazine for a while as the machine did its jiggly business. This project was built using junk found around the studio for a cost of $0.00. It utilizes an old power drill with an offset cam in the chuck for motion.
Step 1The Machine
The Machine
Essentially, it's a power drill with an offset cam in the chuck clamped to a box. The cams were made using a hole saw on 1/8 inch copper sheet, with a thick copper stem hard soldered off center. A good deal of flexibility is available in this detail, as a lot of cam configurations can be used. The pics make it pretty clear how the rest of the thing is made. It's not rocket science, it's art.
46 comments
1-40 of 46next »
Mar 13, 2010. 12:56 PMroboman2444 says:
Cool, but it looks as thought the stylus hugs the wall, maybe making it so the paper is curved so its slightly lower in the center will help.
Apr 13, 2009. 3:35 PMfelixfatts says:
you could easily make this concept more "artistic" by make the amount of vibration variable, and putting a good magnet in the stylus by which you can loosely direct the path of the stylus. or have the center of the stylus be paint and the tips be straws with flow control
Mar 14, 2009. 1:06 PMnatethegreat88 says:
These look more like "How to make your own mace" out of household items or like just replace those pencils with some nails and you have a deadly weapon that could possibly be a shuriken type weapon.
Sep 2, 2008. 7:48 AMfiresketch says:
Any pics with the coloured pencils? Iz nize! : D
Aug 10, 2008. 3:54 PMolof.net says:
you should check out my website, http://www.oolf.net . I started building similar drawing machines, but later found other great ways of visualizing stuff, like wind and so forth. Really nice works
Aug 3, 2008. 5:59 PMkylemcdonald says:
This is a really beautiful example of physical generative art. I'd like to see some larger scale and multi-colored drawings.
Apr 10, 2008. 7:12 PMxxxafterglow says:
Maybe the key to making it minimalist is to restrict either the movement of the stylus (e.g. bigger stylus), the number of markmakers (less pencils) or the amount of time spent. Or you know, sharpen the pencils a lot or use really hard 8Hs or 16Hs. Maybe if there were a way to rig the motion-maker way up high and have the stylus swinging from a string - similar idea but you are limited only by the size of your studio and maybe you'll have to get some friends to grab/release the stylus. Wow this was posted more than a year ago. How's the machine doing?
Apr 11, 2007. 8:09 AMpachanka says:
"art weapon", now thats a cool concept
Mar 20, 2008. 4:04 PMTobita says:
for the art-attack tv series:P
Feb 6, 2008. 4:56 PMheavy.metal.nguyen says:
Hasn't this been posted already? It's nice though.
Feb 7, 2008. 2:28 PMheavy.metal.nguyen says:
Yeah I was wondering why it was at the front of the list. Nice word: astute. Have to use that more often. Makes me sound smart.
Feb 6, 2008. 5:44 AMZengineer1618 says:
Interesting. What if you didn't use a drill ,but instead put the fence assembly on top of a big speaker and then played music /noise/vocals through the speaker? I wonder what kind of images the speaker vibes would create?
Oct 16, 2007. 7:23 PMtechnoplastique says:
I really love the idea of using something like this in a collage or as the base for a drawing. You could use colored pencils. Or exacto knives and film a horror film...
Sep 14, 2007. 12:48 PMLord Of Mystra says:
very cool! *goes drillnapping*
Aug 27, 2007. 4:03 PMmalenamalena says:
um, i take it you are an artist? i teach at a university and am guessing you know about the 'historical' drawing machines, no? if you want, i can refer you to artists who have done this in decades past...but if you read sculpture mag then you probably already know???
Jun 3, 2007. 2:47 AMCanookian says:
Heh. At first glance, I'd thought that you've come up with a contraption from Stephen King's 'The Tommyknockers'
Jan 7, 2007. 2:29 PMKiteman says:
Another styus idea: use a hot pin to poke holes in a ping-pong ball, then use a sringe to fill it with pigment of some kind (paint, ink, etc). If it drainss out too quickly, add cornflower to thicken it. Or why not colour in the whole sheet of paper with pencil, then let a heavy eraser bounce around in there for a while? Or put a handful of iron filings in there for a while, then switch it off and mist with water. Lay another sheet of damp paper over the top, then leave the "sandwich" in a plastic bag for a day or two until the filings rust and stain the paper - you will have a pair of mirror images - then let the paper dry and brush the filings off.
Jan 18, 2007. 8:37 PMStepsoftheSun says:
Various hues of thickened paint in several ping-pong balls sounds like a great idea! Have you tried building one of these, Kiteman? And as an aside to the author, "Dueling Styluses--a Battle of Wills" had me laughing so hard...
Jan 19, 2007. 10:28 AMKiteman says:
No, my Making is usually limited to ideas by lack of space and excess of kack-handedness.
May 24, 2007. 11:50 PMStepsoftheSun says:
Haha, sorry to hear that.
May 8, 2007. 9:13 AMabbiegrrl says:
Wow, that reminds me of a....plasma-something from an old sci-fi movie! ;o) cool idea.
Apr 8, 2007. 9:34 AMT3h_Muffinator says:
Hey! That's quite interesting! Nice job man! you should crush up some chalk and put it in between two pieces of paper, and let one of your styluses bounce around. The chalk would get compressed and smudge on the paper, resulting in a very original piece of art!
Mar 19, 2007. 1:28 PMpoulw says:
As process documentation it does hold some interest. However the beat of the drill is a single note thing and therefore the picts don't hold reward prolonged attention. Find a way to make this polyrhythmic and you'll be on to something. ps- get a job (kidding) yur pal paul
Jan 22, 2007. 3:06 PMroyalestel says:
hayjumper, I want to cultivate as much creativity as you've obviously got. Any hints?
Feb 27, 2007. 11:32 AMroyalestel says:
No sarcasm. I really think this is very creative and I'd like to know if you have any hints on how to cultivate creativity in one's self.
Feb 26, 2007. 10:44 AMFenwick says:
You could put coasters under the paper and get rings. That's be cool.
Feb 24, 2007. 11:45 AMsinner_93 says:
why dont u patent this wonderful machine? you can fill some paint in ping pong ball and attach a few straws.....
Feb 22, 2007. 8:38 PMNumberX says:
I assume that those cams are da bomb? (Get it? You named them Fat Man and Little Boy.)
Feb 21, 2007. 9:14 PMhlumbard says:
I want to see a youtube vid of this thing!
Feb 12, 2007. 3:24 PMlemonie says:
For another idea - heat-sensitive (e.g. facsimile) paper and a hot-lump (of e.g. charcoal). You would cover the paper in aluminium foil to prevent burning & ash/carbon deposits. Then again, regular unprotected paper would produce something interesting(?)
Jan 13, 2007. 1:14 PMpfred1 says:
It looks like toast!
Jan 11, 2007. 5:23 PMfrankenchicken says:
nifty idea... One suggestion to possibly make it even better... You should try making your "pencil ball" thingy with different colors. So when it is running, you will get different "pixels" and it would possibly be able to be even more Rorschach like (you know the ink blot guy.. Rorschach's ink blot tests).
Jan 9, 2007. 12:14 PMscreaminscott says:
Another idea might be to put a rasied design under the paper, and see how that affects the marks on top of the paper. It might come out something like a rubbing or something completely unexpected.
Jan 11, 2007. 7:12 AMKiteman says:
How about a compressible pad (like a piece of camping roll-mat), laid over with a sheet of copper? Replace the stylus with a ball-bearing, and hammer out your design.
Jan 9, 2007. 4:03 PMcrapflinger says:
throw a couple (or more) charcoals (the art kind OR the BBQ kind) or pastels in there and let them rattle around paint your cat's feet then throw it in the box on top...turn the drill on (this has the added bonus of making nice designs on your floor/carpet/furniture/ceiling/face as well) it would also be nifty to keep the drill on the base the way it is to offer the up and down vibration...but then maybe use another drill with another offset cam pointing upwards (instead of horrizontal like you have the one in the base) that would cause the entire top of the contraption (you'd have to make a seperate top for the tray) to move around in a circle...adding a bit more randomness to the mix
Jan 8, 2007. 9:27 PMtimbudtwo says:
Very creative, but why?
Jan 8, 2007. 7:05 PMmabufo says:
Chimps can paint.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:hay_jumper
I too enjoy the satisfaction of creating.
