3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drawing Machine
Step 4The Drawings
The Drawings
Once you have everything in place, plug in your drawing machine and marvel at the wonder of the artistic process. The machine can be clamped down to a table, which will restrict the motion of the machine, or it can be let to run free around your shop. Make sure you have adequate extension cord allowance if you opt for the latter, and it's a good idea to check on the little bugger every so often. Mine tended to wedge itself quite firmly under tables if I wasn't careful.
The possibilities are endless. I've since modified this machine to accomodate 20 by 30 inch paper, and I've also made teeny tiny drawings. Some other ideas include using a sharp, steel stylus on copper plate with an acid resist applied. The marks made by the machine would then be etched in an acid bath. Monoprints anyone? Or the machine itself could be used AS the stylus to make super huge drawings.
Here are but a few of the drawings I made using this machine.
4 comments
Mar 13, 2010. 12:56 PMroboman2444 says:
Cool, but it looks as thought the stylus hugs the wall, maybe making it so the paper is curved so its slightly lower in the center will help.
Apr 13, 2009. 3:35 PMfelixfatts says:
you could easily make this concept more "artistic" by make the amount of vibration variable, and putting a good magnet in the stylus by which you can loosely direct the path of the stylus. or have the center of the stylus be paint and the tips be straws with flow control
Aug 10, 2008. 3:54 PMolof.net says:
you should check out my website, http://www.oolf.net . I started building similar drawing machines, but later found other great ways of visualizing stuff, like wind and so forth. Really nice works
Jan 8, 2007. 8:21 AMmbolding says:
very nice
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:hay_jumper
I too enjoy the satisfaction of creating.
