Introduction: Dream Sequence Terrarium
This is a unique spin on trying to create a dream sequence within reality in using a confined space.
DIFFICULTY: Moderate
TIME: 30 Minutes
COST: about $15
USES: decoration, gift
What you need!
-Mason Jar
-Canvas Paper (5 inch by 6 inch piece)
-Cotton Balls
-Adhesive Stars
-Glitter
-Ribbon
-Thread & Needle
-Tongs
-Scissors
-Rubberband
-Optional: Small figurine to add in scene
Step 1:
Step 1:
Pour glitter into mason jar,
this makes the ground of
the terrarium!
Step 2:
Step 2:
If you decided to use a
figurine, place in now
with tongs.
Step 3:
Step 3:
Take your 5x6 canvas
paper and pull it tight
over the jar to create an
imprint, then take it off
Step 4:
Step 4:
Put thread through needle, and then put through cotton ball, then make a knot around the cotton ball so it hangs from the string
Step 5:
Step 5: Thread the needle (& thread) with the cotton ball attached and then tie a knot. Follow the pictures, the goal is for this string and cotton ball to hang from the canvas paper
Step 6:
Repeat the cotton ball maneuver as many times as you want the cotton balls to show in your terrarium. These are supposed to be clouds!
Step 7:
Step 7:
Now, do the same but with the stars. The stars are adhesive and will just stick to the ends of the string. So just thread the needle (&thread) through the canvas paper and then stick the stars on the ends. Follow the pictures!
Step 8:
Step 8:
Put your canvas paper on top of the jar and your dream sequence will appear like magic! Next, put a rubberband over like the picture shows.
Step 9:
Tie your ribbon on and then take off the rubberband
Step 10:
& VOILA!
You’re done!
You have succesfully created a unique scene that is to depict a dream
sequence, because the situation is not likely to happen. Enjoy this mini escape into another world- the dream sequence.
