Dremel
Published
Introduction: Dremel
Don't have the money to buy a dremel? We'll now you cand for less than 5$!!!!
Step 1: Materials
- motor
- 9v battery
- 2 coins (I prefur pennies)
- lots of wires
- 2 containers
- electric tape
Step 2: Tools
- screwdriver
- knife
- wire strippers
- hot glue gun
Step 3: Hole in Container
Use the tip of the screwdriver to hammer a hole for the wires in the first container.
Step 4: Add Wire and Tape
Atach the wire to the motor and tape together
Step 5: Put in and Glue
Put in motor and glue on with hot glue
Step 6: Attach Wire
Attach one of the ends of the wire to the battery and glue on to secure
Step 7: Attach Penny
Use electric tape to attach the wire, then glue the tape
Step 8: Attach Penny to Container
Glue the penny on the container as shown in the image
Step 9:
Glue good
Step 10: Tape
Tape another wire to the penny and add the second container
Step 11: Attach
Tape the other end of the wire that is attached to the penny to the back of the second penny
Step 12: Attach Penny
Glue the penny to the container
Step 13: Secure Wire
Secure the wire that is attached to the battery so that the tip is over the penny
Step 14: Glue Container
Glue the second container secure
Step 15: Tape
Tape the dremel but don't cover the penny
Step 16: Make the Blade Attachment
Smash a bottle cap and do as shown in pics
Step 17: How It Works
When your hand holds the dremel it pushes the wire on the penny completing the circuit causing the motor to spin.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    9 Comments
    If you think that it is powerful, try getting your hands on a real dremel. There is no way that that can even cut thin cardboard...
    Yeah, I know the power of the real ones, for I own one myself. However, this thing is pretty strong, if can cut through wood it you take it slow. I like to use it for sharpening my pencils? I do know it is not even close to a small portion of the real ones, for I have cut solid steal with mine. It works on soda cans and such though.
    very excited to try at home...
    just wanna ask, how to make the blade mount? the image lil bit blurry :(
    greets from Idn :D
    ok first hammer down a bottle cap.get a small circular piece of rubber and poke a hole in the middle. fill the hole with glue and stick on the tip of the motor. then glue the bottle cap on the other end of the rubber circle. if u want, u can sharpen it.
    also you should change the name of this project in "dremel-like diy cutter" or "
    dremel-wannabe cutter"
    nice. now make a circuit that controls the speed of the motor using a 555 timer and a power transistor and i think you should try lithium cells connected in series. it's gonna be really powerful
    XLG has a good point, this is a very inventive project, I especially like your 2 penny switch
    It's actually really really powerful
    Dremel is a registered trademark and has copyright on the name.
    What you have it as best a low powered rotary tool (this is the proper term).
    Neat idea though.
