3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dremel 395- Not working, repair
My Dremel 395 quit working when I was twisting the wire counter-clockwise to get it into my z-axis mount. I read on the forum where someone tested 6.5/7 ohms between the stator wires.
One of mine was broke so I fixed it! I hope someone else can use this to fix theirs too.
First determine if your stator has 6.5/7 ohms between each coil set. There are two coils to test. If there's no reading then you have a short. If one is broke then you have to solder it back! The problem is that the wire is now too short to put back into the connector. The solution is to (not in this order) solder a tab onto it and reconnect it with the pin.
Step 1Pull pin out/ drill hole
Pull the pin out with some small pliers or a jewelers flatHead screwdriver might work. Notice the slit in the bottom the wire needs to be  around .002". First though drill out the bottom of the slit on the inside of the stator housing so the new wire won't get pushed out, well that's probably optional though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:treflip
