3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dremel Carved Painting Roller Sleeve
Design rollers are like rolling block prints.  They can be used as painting tools to liven up a painting with patterns.   They do the job well, and quickly.
This particular roller sleeve is carved with a dremel tool with a ball-shaped burr bit.  It paints parallel wavy lines.  Other carved designs will paint other designs.
1 1/4" PVC pipe sections can be used as the basic sleeves for standard paint roller handles.  Besides carving, you can also adhere materials to the sleeve to make designs.
Step 1Carving the Sleeve
Carving the Sleeve
To hold the pipe section in my vise, I slipped it over a longer piece of 1 1/4" diameter pipe slit up one side and rolled to fit inside.  As it expanded, it held the pipe section to be carved firmly.
Pencil your design and carve away.
10 comments
Nov 12, 2010. 6:28 PMantling says:
Thanks! The reason I asked is because we just bought a new house and the walls are kinda empty and boring..
I am still thinking of how to spice it up besides hanging stuffs to it..
Thanks for the tips and i guess, next is to select colour to make the rooms look more spacious.
wish me luck!
Nov 14, 2010. 4:23 PMantling says:
Really thank you for your advise.
I had 2 more concealed electrical points to take care of.
According to my schedule. I should be able to begin the painting week after next.
Thanks
Nov 12, 2010. 4:54 PMantling says:
cool!.
Do you have any sample for wall painting?
Nov 8, 2010. 2:50 PMUncle Kudzu says:
Interesting! Is there any problem with a seam showing in the print in the case of using the viynl fabric? Does the PVC hold much paint/ink on its slick surface if use without fabric?
Nov 9, 2010. 10:35 AMUncle Kudzu says:
Ok, after looking more closely at the photo, I understand what you did with the vinyl fabric.
I have seen a linoleum block carving that had a loose flocking material glued to the printing surface. Something like that would hold more paint. I love the idea of carving the PVC pipe with a rotary tool. Thanks for sharing!
Nov 12, 2010. 9:04 AMrrrmanion says:
to avoid the edges fuzzing up, how about like a hybrid? part one part the other?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
340
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
